Forum topic by WalnutRidge | posted 09-25-2011 06:50 AM | 1074 views | 0 times favorited | 5 replies | ![]() |
Topic tags/keywords: pine I just moved not to long ago, and with it came the new shop. I just got finished build a set of kitchen cabinets out of it, and realized how desperately I need more workbenches. I have a friend who has a bunch of pine he is going to give me. I really like the rustic look of pine with just a clear finish and no stain. (However my wife doesn’t so I can’t build anything out of this to put in the house) So I thought it would make for nice looking benches. Due to the nature of pine being soft and such. Is this a poor idea? And and all help appreciated. -- Josh- What you put in determines what you get out. |
5 replies so far
#1 posted 09-25-2011 07:40 AM |
Hey walnut, it depends on what your use for the bench will be. a bench for just general working and laying stuff on it untill you get around to using the stuff. or a bench for pounding, sawing,carving and planing. the first bench i mentioned, pine wood be ok; but the second senario, i would not…unless the pine is 2 1/2 to 4 inches thick. in my ever so humble opinion. |
#2 posted 09-25-2011 02:49 PM |
Go out and get yourself a 36” solid core door blank. Use your pine to wrap the door edge, build the legs, add a shelf or drawers or whatever you need. You can be up and running in short order. We have 2 benches like that, one we keep a MDF sacrificial cover on for sawing, sanding, routing, and such. The other has a roll of paper mounted under one end so we can roll it out and cover the bench for finishing and other dirty work. Les -- Stay busy....Stay young |
#3 posted 09-25-2011 02:51 PM |
I have 2 pine benches in my shop. One is made from rough sawn 2×12’s and one from pine 2×4’s making it 4” think. Although neither is my primary workbench, they both perform admirably. As doordude said, it really depends on what your looking to do. If woodworking is a hobby, and your doing it now and then, a “good” pine workbench will outlast you. The other option, build it out of pine, and if you find you don’t like its durability, add a piece of maple or other hardwood ply to the top. My bet is you never add anything and the pine will work just fine. -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
#4 posted 09-26-2011 01:12 AM |
My main workbench is made from yellow pine with a double layer of 3/4” plywood for the top. For my new shop I built 3 temporary workbenches from Fir and OSB. I can do just about what I want on the temporary benches excluding heavy pounding. -- I don't make mistakes, I have great learning lessons, Greg |
#5 posted 09-28-2011 03:29 AM |
Thanks for the input. Hopefully i can get started on them before to long! -- Josh- What you put in determines what you get out. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
