creating a wagon vise and a leg vise
Forum topic by benchbuilder posted 09-24-2011 05:29 PM 7019 views 0 times favorited 2 replies Add to Favorites Watch
View benchbuilder's profile
benchbuilder
284 posts in 2325 days
09-24-2011 05:29 PM
Does it seem reasonable to use a small front vise with guide rods mounted under the workbench to use as a wagon vise. This would have the outer face plate mounted to the workbench and not moving and the center of the vise where the drive screw passes through would now move as it is not screwed to the bottom side of the bench top. The back of the guide bars of the shoulder vise would be set into a block and mounted to the bottom of the workbench. A small block mounted to the center now moving section of the vise and rising up through the slot in the workbench top with a dog hole and dog in it to act as the clamping member. The large front vise with guide rods could also be used to create a leg vise by building a leg around the large shoulder vise mounted vertical in it. The bottom of the leg vise would use one guide roller as in another well known designed leg vise. The use of the large shoulder vise would only need one guide roller at the bottom of the leg vise as the shoulder vise having the long guide rods would help keep it moving smoothly. Just an idea, any thoughts or other ideas on this. This would give you two vises for less than the cost of one of the popular systems on the market.
2 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3523 days
#1 posted 09-24-2011 05:52 PM
Most wagon vises use a shoulder vise screws. should vise does not have guide rods though – thats a face vise. shoulder vise is just a single screw like this:
I used just a regular tail vise screw for my wagon vise:
http://lumberjocks.com/PurpLev/blog/17919
benchbuilder
#2 posted 09-24-2011 06:38 PM
From “Highland Woodworking” they list a vise that yes I would call a front vise but they list it as a shoulder vise. I have edited the question
