| Forum topic by MsDebbieP | posted 634 days ago | 1390 views | 0 times favorited | 15 replies | ![]() |
634 days ago |
Topic tags/keywords: tips tricks proportions ratios what are your tips re: “best” proportions for projects, ex: chairs, tables, boxes…? (also add links to helpful blogs etc that are related to the topic) Gateway to all Tips & Tricks Topics -- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
15 replies so far
#1 posted 634 days ago |
I’ve been studying art all my long (so far) life and I conclude this: Because of these feelings, I have little use for the “classsical” rules of proportion. Not (as Seinfeld says) that there’s anything wrong with that, but it doesn’t impact my personal feelings about design. For example, I built a set of library units for a room in which they cover one wall, transition around the corner and end with another set on that adjacent wall. They fit floor to ceiling and begin and end at doorways. And, then there is the requirements of the client. Since this set of units will be a permanent part of the house it would have to be something the owners could live with. Other furniture, like tables and chairs, have to be ergonomic and a technical approach to proportions could be, but not necessarily, a disturbance to that requirement. But certainly the overriding feature would be that it actually fits people and doesn’t make them uncomfortable. In cases like a free standing desk or sideboard, the golden ratio could be considered, but I, personally, don’t feel it should be in control of my design. ddwwb -- The best things in life aren't THINGS. |
#2 posted 634 days ago |
it sounds like it is one of those “know the rules so you can break the rules” So true re: comfort. Oh how I’d love a chair that fit my dimensions. I hate sitting on a chair that “makes” me slouch/slip to the floor because it doesn’t fit. -- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
#3 posted 634 days ago |
Two parts whiskey, one part glass… I finished that “project” last night and the proportions were perfect. -- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
#4 posted 634 days ago |
I agree with Don on not worrying too much about the rules. Build what is pleasing to the eye. If you are happy with the result, then you have succeeded. If you build something (let’s just say a box) and you don’t think it looks quite right, then you need only compare it a box that you like and see what is different about the proportions. Try again. Lather, rinse, repeat. :-) -- Charlie M. "Woodworking - patience = firewood" |
#5 posted 633 days ago |
When I am concerned about proportion, I will draw up a series of sketches, slowly shifting the shape and then pick what looks best. As a simple example, say a want a nice looking rectangle. Maybe for a mirror to hang on a wall. I would first draw the rectangle as I think it should look. Maybe include the wall to get a feeling for how it will fit in. Then, just to make sure, I draw a couple that are progressively taller and some that are shorter. Usually vary the ratio slightly. Then pick the best one out of that lineup. Often it is the initial drawing, but sometimes not. Either way, I have more confidence about my choice. I usually don’t do this for a simple rectangle, but when shapes are more complicated – like curves for a turning or the relative size of a series of panels. -- Steve - Impatience is Expensive |
#6 posted 633 days ago |
I’m a Fibonacci fan for lots of things -- Grumpy - "Always look on the bright side of life"- Monty Python |
#7 posted 633 days ago |
I generally make small articles to fit the object I’m going to put in it. I’ve made shadow boxes that had a niche for each object. Tedious, but that’s the art of it. The shadow box itself would end up taller than shorter, often as not, and close the Golden Ratio, but I’m not married to it. In the case of a one-off like a spectacles case, it’s the size that will enclose the specs, with little room to spare. Imagine making them in production, what with all the different size specs on the market. |
#8 posted 633 days ago |
there are some great blogs here at LJ re: golden rule and Fibonacci (or Faberge Egg thingy, as I call it)... which are your favourite blogs? -- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
#9 posted 633 days ago |
I am personally a fan of learning the classic rules for proportion, design and ratios and then breaking the rules on a regular basis. -- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt |
#10 posted 633 days ago |
I agree, if we didnt break the rules,... then everything would,... well look the same -- Doug... |
#11 posted 632 days ago |
On of the hardest things to do(that I have encountered) is the placement of hardware on a piece that has multiples. Chest of drawers is a good example. Years ago when faced with this problem I hit upon an idea that has held me in pretty good stead. When I begin to work on the placement (particularly a chest with graduated drawers)I place the hardware on the centerline of a drawer at an arbitrary distance in from the edge. Then I begin to establish straight lines between at least pieces of hardware. Sometimes this necessitates raising the position of the hardware above the centerline of the drawer(never lower) and sometimes it requires moving in or out out from the edge. When I am satisfied that I have as many straight lines as possible that is where I will mount the hardware.I do not consider the angles of the lines.For an example check out the Queen Anne chest on frame in my projects. -- "certified sawdust maker" |
#12 posted 632 days ago |
Just do it by eye. When I was in high school shop was everything one might need on a farm; ie, very little woodworking. We had to have a project for the last 1/2 of senior year. I decided to make a gun cabinet. I knew nothing about design or cabinet or furniture making. I had never heard of Fibonacci. When I did learn of Golden Ratio, ect, I measured the proportions of the gun cabinet and the trim I had designed. I was surprised to see how close to exactly on it is. If in doubt, I now just use Fibonacci ;-)) -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence |
#13 posted 632 days ago |
I agree with everyone, and especially Lis -- Roger from KY. Work/Play/Travel Safe. Kentuk55@bellsouth.net |
#14 posted 627 days ago |
David posted an informative blog on the FIBONACCI SCALE and the GOLDEN RULE: his blog -- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
#15 posted 626 days ago |
I think that this is a tricky area, which doesn’t strictly come down to technique. |
| Forum | Topics |
Woodworking Skill Share
8847 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15982 |
Hand Tools
2098 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
