miter clamping with ease
Forum topic by Dusty56 posted 09-23-2011 09:55 PM 2286 views 1 time favorited 18 replies Add to Favorites Watch
View Dusty56's profile
Dusty56
11819 posts in 3596 days
09-23-2011 09:55 PM
Topic tags/keywords: jig resource clamp miter saw
I was thinking about making some picture frames but didn’t want to buy any more specialty clamps and along came this video tip from Woodsmith in my emails. : )
I hope you might find it helpful as well !
http://www.woodsmithtips.com/2011/09/22/foolproof-miter-clamp/?utm_source=WoodsmithTips&utm_medium=email&utm_campaign=5156
18 replies so far
View cloakie1's profile
cloakie1
204 posts in 2463 days
#1 posted 09-23-2011 10:12 PM
great idea….thank you very much for posting
-- just get stuck in and have a go!!!
View degoose's profile
degoose
7228 posts in 3263 days
#2 posted 09-23-2011 10:17 PM
Thanks Len… that is a great tip… and so simple…
16272 posts in 4127 days
#3 posted 09-23-2011 10:54 PM
I’m saving this because it seems like a great idea. However….. I have learned through experience that my miters are never 100% dead-on 90 degrees. As long as they are pretty close, a band clamp that pulls all four corners together at the same time will equalize the inaccuracies and give you a pretty good result.
Using the one-corner-at-a-time method in the video will work fine if your miters are perfect. If not, though, you’re going to glue three corners up and find out the fourth corner is wayyyy out. (Don’t ask me how I know this.) :-)
Having said that, I probably need to work on more accurate miters, and then this method shown in the video will be a big help.
Dusty56
#4 posted 09-23-2011 11:17 PM
Charlie , I am well aware of “the perfect 3” !!!
I’ve always heard that anyone can make a perfect 3 sided frame…..LOL
6846 posts in 3888 days
#5 posted 09-24-2011 12:07 AM
Great tip, Len.
TopamaxSurvivor
18199 posts in 3584 days
#6 posted 09-24-2011 12:17 AM
beat cha ;-)) http://lumberjocks.com/topics/30286 ;-))
View PurpLev's profile
PurpLev
8534 posts in 3557 days
#7 posted 09-24-2011 02:18 AM
Charlie – how DO you know this?!?
View DarrylJN's profile
DarrylJN
261 posts in 2472 days
#8 posted 09-24-2011 02:32 AM
That is a great idea and I plan on using that one ASAP!
-- Darryl ~ Waxhaw, NC
PurpLev
#9 posted 09-24-2011 02:39 AM
This reminds me though – in the woodworking show that took place in Springfield, MA last year one of the presenters was marketing finishing and related products. he demonstrated a technique to glue miters easily and quickly using nothing more than brown paper (he joked about how we could just use the paper bags from the grocery store, of he can sell us one for $50).
the technique was based on the fact that paper is thin and glueing it to underside of the parts being mitered-jointed together dries very quickly “locking” the paper to both parts in a matter of ~30sec at which point you can just leave it as is for the joint itself to dry as it is already locked in position and without the use of clamps all together – that was a pretty cool technique… never glued up miters since though ;)
TopamaxSurvivor
#10 posted 09-24-2011 03:42 AM
PurpLev, How does the glued paper dry in 30 seconds?
View gfadvm's profile
gfadvm
14940 posts in 2598 days
#11 posted 09-24-2011 04:52 AM
I needed more than the one band clamp I own to glue up a big shadow box (48”x23”x6”) yesterday and I am too cheap to buy another $30 band clamp. I improvised with a 1” ‘cargo strap’ ratchet. This worked very well! And they are cheap! You guys probably already knew this tip but it was new for me. I never use the corner block plastic thingys that came with my band clamp. Charlie – I used to be a 3 good miter guy. Then I solved this problem with my ‘Super Sled’. Probably the most useful thing I ever built.
View jack1's profile
jack1
2099 posts in 3936 days
#12 posted 09-24-2011 07:10 PM
THat looks good. Thanks.
PurpLev
#13 posted 09-24-2011 08:13 PM
Topamax: since the paper is only a few 0.001” thick the glue penetration process happens fast, and the drying time is quick as well, it does not have to be fully dry in order for the paper to grab a good solid hold of the wood to act as a clamp. the guy was demonstrating it live and it was quite impressive to see and test it within a minute or 2
View Sawkerf's profile
Sawkerf
1730 posts in 2977 days
#14 posted 09-24-2011 08:30 PM
That gadget will give perfect miters every time since that method automatically compensates for small errors in the angles. IOW, if one is at 46 the other one will be 44 and the miter will be a perfect 90*. No big deal unless the frame has a lot of detail which will be a bit off if the miters aren’t perfect.
Like Charlie says, the other problem will be that the first three miters will be fine, but unless the fourth cut is made on pieces EXACTLY as long as the others, the miters won’t close up right.
Dusty56
#15 posted 09-25-2011 01:20 AM
TMax, I saw the same display at the show as Sharon did….it was impressive ,but I haven’t tried it yet myself.
Actually . I think the Partimers set in and I forgot all about it until reading Sharon’s comment here.
