Help! Will it hurt my 2hp cab. saw if I run it on a 30amp breaker?
Forum topic by jeff73 posted 09-23-2011 09:34 PM 995 views 0 times favorited 6 replies Add to Favorites Watch
View jeff73's profile
jeff73
4 posts in 2436 days
09-23-2011 09:34 PM
Just wiring my shop for my latest shop aquisition, a 2 hp jet cabinet saw. I have a 30 amp breaker in hand. Is it harmful to the run the saw on so much amperage?
View lew's profile
lew
12060 posts in 3754 days
#1 posted 09-23-2011 09:40 PM
The amp rating is the MAXIMUM current you can draw through the circuit. The saw will only take what it “needs” to run.
If you use a 30 amp breaker, make certain you use the correct wire size for that amperage.
4986 posts in 2492 days
#2 posted 09-23-2011 09:48 PM
Absolutely no problem at all. As mentioned, that 30 amp needs #10 wire running to the outlet. But any of your 240V tools can run on it.
View Richard's profile
Richard
1916 posts in 2689 days
#3 posted 09-23-2011 10:02 PM
Not at all, like lew said it only takes what it needs. What might hurt is to run a 20amp machine on a 15amp line as it might run but not very well and then you would be popping the breaker all day as well.
jeff73
#4 posted 09-24-2011 12:17 AM
Thanks for the replies! Sounds good. I have 8-3 wire with a separate 10ga ground wire running temporarily since the shop is about 70 feet from house. I picked up some 4ga wire that I havent had a chance to hook up so i think this will hold me over for a bit.
The manual says it has an overload switch so i will breathe easy.
I just signed up on this sight and DANG it is great. Will be back at this sight often.
TopamaxSurvivor
18271 posts in 3675 days
#5 posted 09-24-2011 12:25 AM
You didn’t mention the operating voltage. The code allows for 50 amp on 120 v and 25 on 240. Since very few brands make a 25, 30 is the next standard size. With #8 yoiu should not have any low voltage problems.
BTW, WElocme to LJ!!
jeff73
#6 posted 09-24-2011 03:20 AM
Aha so I guess its the 30 afterall! I am running 240v
thanks Topamaxsurvivor
