Any one familiar with using a thread chaser?
Forum topic by Michael1 posted 610 days ago 1267 views 0 times favorited 10 replies Add to Favorites Watch
View Michael1's profile
Michael1
405 posts in 832 days
610 days ago
Topic tags/keywords: cutting threads in wood thread chaser lathe teqniqes
I have recently been researching ways to cut threads in wood, say for a lidded bowl turning with a screwed on lid. I have came across some neat techniques like using PVC plumbing parts and gluing the female threads into the bowl and the male threads to the lid.
However, at the Woodcraft store I came across a hand tool grouped with the lathe chisels called a “Thread Chaser” It looked similar to a small skew chisel but the business end of the tool was at a 90 degree angle from the handle. My question is how do you use it? Is it really used to cut threads and how do you go about it?
-- Michael Mills, North Carolina, http://www.scicaskets.com
10 replies so far
View Gary's profile
Gary
3556 posts in 1605 days
#1 posted 610 days ago
I cut threads now and then. I use the Beall thread stuff. Both to thread dowel and to make the nut part. Works great.
View crank49's profile
crank49
2291 posts in 1144 days
#2 posted 610 days ago
The only thread chaser I have used was like a sort of file with teeth cut to fit the size thread I wanted to chase.
The act of chasing threads is, to my understanding of the term, to repair existing threads.
Making new threads would be called cutting threads or simply tapping a hole in the case of internal threads.
I have heard the term used to describe running a tap through a threaded hole to clean up the threads, as in “chase the threads with a tap”.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Bob Kollman's profile
Bob Kollman
1779 posts in 1363 days
#3 posted 610 days ago
A thread chaser is used for cleaning up threads. Not made for cutting new threads.
If you have a metal turning lathe you can cut large diameter threads in most any
material. For anything over an inch you would probably need to look into pre made
thread inserts. If you have a bridgeport mill there maybe some thread forming tools
available.
-- Bob Kenosha Wi.
TopamaxSurvivor
13194 posts in 1848 days
#4 posted 610 days ago
The Woodwright, Roy Underhill, had an episode a few years ago about making some threading cutting tools.
View 000's profile
000
3352 posts in 789 days
#5 posted 610 days ago
I’ve seen this being done. There’s a few you tube videos just google them
The trick – and it’s a trick – is to let the thing catch while you move it from right to left then hang on as it self feeds.
-- When the moderator chooses sides, his site sucks.
View hairy's profile
hairy
1763 posts in 1705 days
#6 posted 610 days ago
http://www.youtube.com/watch?v=7Qi9q2BV3ss
-- It must be jelly baby, cause jam don't shake like that...
Bob Kollman
#7 posted 610 days ago
I’ll be …. there is a thread forming tool form the wood lathe….Learn something new every day!!!!
http://youtu.be/c-j16CrwHeM
-- Bob Kenosha Wi.
View rance's profile
rance
3856 posts in 1333 days
#8 posted 610 days ago
There’s lots of thread chasers here on LJ. You look at one thread, then down at the Pulse page and… bing, you’re off on another thread. I’ve spent DAYS chasing threads.
Seriously, check out the Thread Master. THAT’s the one I drool over. A similar idea here.
Michael1
#9 posted 610 days ago
Thanks for the Link Bob. that answered my question of how to use this tool.
View horologist's profile
horologist
75 posts in 1912 days
#10 posted 610 days ago
I have some limited experience in using thread chasers on an antique treadle lathe. The best source for instruction I have seen is the DVD by Allan Batty. Available at Craft Supplies USA=.
-- Troy in Melrose, Florida
