Any one have this bit
Forum topic by therookie posted 09-23-2011 04:18 AM 1303 views 0 times favorited 11 replies Add to Favorites Watch
View therookie's profile
therookie
887 posts in 2852 days
09-23-2011 04:18 AM
I am building my maloof music stand and I have to put a 1.5” hole through 13.25” of wood. Well using a drill press is sorta illogical. So I was wondering if any one has a 3/4” core box bit so I can rout four pieces of wood and glue them together. So I am wondering if I could borrow one or rent one? Don’t want to buy a brand new one if I only have two parts to make.
Thanks Adam
-- http://aewoodworks.webs.com
11 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3093 days
#1 posted 09-23-2011 04:49 AM
Does the hole have to be perfectly cylindrical? If it does, your idea will get you close (if you’re realy careful), but you’ll still need to fiinsh it off to get your cylinder.
If a cylinder really isn’t necessary, for rabbets could give you what you actually need.
View Dez's profile
Dez
1166 posts in 4102 days
#2 posted 09-23-2011 06:42 AM
An extension for bits is available. I have one somewhere!——-
-- Folly ever comes cloaked in opportunity!
TopamaxSurvivor
18286 posts in 3700 days
#3 posted 09-23-2011 08:03 AM
Going through that much wood, I would look at a self feeding like a planetary.
View DFDS's profile
DFDS
8 posts in 2465 days
#4 posted 09-23-2011 08:11 AM
I was just going to make a new post and yours what at the top of the list…I’m actually considering a similar need and looking into this bit: http://www.toolstoday.com/p-4971-core-box-router-bits-extra-deep.aspx
or one of these: http://www.carbidespecialties.com/CT_Grooving_Bits.htm#Ball_End_Router_Bits
Seems like a plunger will do the job.
For my application, I’m looking to make half spheres at a depth of 3/4”.
Anyone used these bits and found plunging effective?
Thanks,
DF
View thedude50's profile
thedude50
3603 posts in 2502 days
#5 posted 09-23-2011 08:53 AM
I have an augur bit that size and a brase to drill the hole i think its about 14 inches long do you want me to check
-- Please check out my new stores http://woodratnest.com and http://woodshopstore.com
therookie
#6 posted 09-23-2011 12:02 PM
The dude if you could look I would appreciate it and dez if you could too I would appreciate that too
View mtenterprises's profile
mtenterprises
933 posts in 2717 days
#7 posted 09-23-2011 01:14 PM
You know you could cove this out on your table saw and glue the 2 pieces together. It all depends upon the depth of your saw blade and angle of attack entering the blade. Practice first on 2×4s and take shallow passes untill correct angle is found and depth is met. A thick sharp carbide tipped blade works best for this since it is like side cutting.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Bluepine38's profile
Bluepine38
3379 posts in 3110 days
#8 posted 09-23-2011 04:26 PM
Irwin makes expandable wood bits, the older micro-dial bits I have are for a brace and bit, I have used this
type to drill up to 3” holes through various layers of wood, do not know of an extension that would fit
on this type of square shank bit, although we did cut one in half and welded pipe couplers each end and
used pipe extensions to drill through an old log house section to wire it. Irwin has a newer one with a
round shank on it that could be used with a 1/2” or bigger slow speed electric drill, and the spade bit
extensions that are readily available would work on this bit. You just have to be careful and rig up a steady
rest for the drill and the wood you are drilling, but it can be done.
thedude50
#9 posted 09-23-2011 07:14 PM
ok i am on my way to the shop ill let you know what i find
mtenterprises
#10 posted 09-23-2011 10:53 PM
cr1 I’ve seen your idea done for other things like molding this would work very well in this case because of the 13” depth. Could even be done with a back saw by hand. No need of special tools Great!
MIKE
thedude50
#11 posted 09-25-2011 09:44 PM
ok i have the bit and a brace pm me and well work out how to send it to you
