I am new to turning and have a set of gouges. I have sharpened many knives over 20 years as a chef. I see the stones for the grinding wheels, if I am as good as I think I am, can I have sharpen the gouges? Should I make some guides for the specific angle of my gouges? Or am I wasting my time and should give the bullet and make an investment? Is there a brand or system that it preferred? Thanks so much for the help. Seth
You obviously have some idea what sharp is like. When your lathe tool fails to cut like when it was new try grinding the cutting edge on a slow speed grinder, maintaining the original angle of the bevel. Go slow so you don't overheat the edge. Try in on your woodturning project. Still dull? Try again.
Dont know if you would be wasting your time free hand sharpening spindle and bowl gouges but its a waste of time and $ for me. If done daily I'm sure I could eventually do it, but what happens to those skills when I dont turn for a few months, which happens annually for me. Suggest you bite the bullet and get or make a jig .
8" slow speed grinder with friable wheels, not the usual grey ones. Jigs - they can be made cheaply, like Capn Eddie's, but those have limitations in the grinds produced. Its worth it to get a Wolverine system with the vari-grind 2 so that you can create about any grind desired. Grinder and jig $250-$300.
Hand sharpening gouges would require a lot of skill IMO and even for the most skilled would probably still be terribly inefficient. Recommendations above all good. I used a 6" VS grinder personally with shop-made jigs. One "trick" to gouge sharpening is the type of grind and making sure the sweep is symmetric. At least for me, if I cut one direction and turn to cut back in the opposite direction and there is a difference in the grind, it doesn't cut the same. Even a slight variation can cut into my "mojo" ;-)
These LJ's are right on. Capt. Eddie Castelin has all the sharpening videos you need and his website sells great carbide cutters at great prices. I use his carbides for my chisels which I love. When my skews, bedans, cutoffs, and special grinds need a touchup but not a sharpening, I use a 1" sanding belt. I bought a cheap 1" sander with a 6" disk at Loews. Klingspoor has every kind of belt you can think of at reasonable cost. I also have a leather wheel and a buffing wheel I made with a belt driven arbor and an old washing machine motor. Great Information Guys!
I'm new to this turning thing also. I quickly realized that sharpening and sharpening well were critical to "success" in this venture.
Knowing that I'm not experienced at sharpening, I opted for the low speed grinder with CBN wheels and the vari-grind jig/tool rests. With these, even I can get most of my tools sharp. Expensive initial investment though.
I also have a Tormek wet grinder. I like the wet grinder for narrow angle tools, likes skews, because they can easily overheat, even on CBNs (at least with me operating them). The wet grinder is also "better" for hollow grinding chisels, again for me.
Now if your angles are set right and you are experienced at free hand sharpening, you may not need any of this. I've watched the pros (like Stuart Batty), hand sharpen off of a simple rest
I use an 8" grinder form lowes, and a wolverine jig.
I also use a 180 grit CBN wheel. I got my wheel from woodturners wonder.
About the best deal out there. https://woodturnerswonders.com
what about the worksharp 3000?
I really was thinking of seeing what a Wen 8" wet grinder (tormek clone) can do for $100, but then… I have the worksharp 3000 already.
I resharpened all my tools today using the one-way rest and vari-jig. First time I've sharpened some new Thompson gouges I recently purchased. All turned out great. Getting better at this. One thing that helps is to note your rest angles and mark you tools using electrical tape with the rest angles. It forces you to think about it a bit more and easier to get back there each time you resharpen.
Holbs, I used the WS3000 for a few years, and finally got tired of cleaning adhesive from the wheels, the platform jig for scrapers kept slipping (even when using loctite)...it worked really well, but never felt natural to me. I finally pulled the trigger on the cheap Rikon slow speed with a Wolverine jig and CBN wheels this year. I'll keep my WS for chisels and plane irons, but man, I love my grinder so much more for lathe tools.
I tried it, even bought a jig meant for the tormek that the WS3k recommended together with its bar. I ended up giving up and springing for the wolverine. And then a slow speed grinder (Rikon). And better wheels. And ended up MUCH happier.
I keep the tormek jig (~$80) as a reminder to not be smarter than everyone else, and just get what most people recommend from the beginning! (Also got no bites on a second hand site I tried to sell it on haha).
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
