How do you know when your blade is dull.
Forum topic by agallant posted 09-22-2011 07:22 PM 1102 views 0 times favorited 10 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2793 days
09-22-2011 07:22 PM
I have been contemplating sending my Forrest WW2 out for sharpening. It is not chipping or burning per-say but it is requiring more effort to push wood through it. How do you know when it is time to change the blade out with a sharper one?
10 replies so far
13594 posts in 3248 days
#1 posted 09-22-2011 07:24 PM
the problem you are having with it
would be a good indication
View knotscott's profile
knotscott
7874 posts in 3282 days
#2 posted 09-22-2011 07:30 PM
You’ll get the same symptoms when the blade is dirty too….which of course will eventually cause premature dulling.
View ShaneA's profile
ShaneA
6889 posts in 2505 days
#3 posted 09-22-2011 07:34 PM
That is a good question. Keeping the blade clean can help with the resistance issues. Since dulling occurs slowly over time it can be difficult to notice. However, if you have a sharp/clean blade to compare it to, that may give you sort of an instant response. After I sent my wwIIs to forrest for sharpening, the difference was substantial. Now I wonder why I waited so long. Same can be said for planer/jointer knives. But, once you have sharp, you will know dull if that makes sense.
View jlsmitty's profile
jlsmitty
14 posts in 3517 days
#4 posted 09-22-2011 07:41 PM
I sent my WWII to Burns Tools (do a google search)and was very pleased, as good as Forrest (maybe better) and cheaper.
View Sawkerf's profile
Sawkerf
1730 posts in 2975 days
#5 posted 09-22-2011 08:21 PM
Take a look at the teeth. If you see grunge on the faces or sides, a good cleaning might be all that you need. At the risk of starting a war, I’ll suggest using Simple Green. If the cleaning doesn’t improve performance, it’s probably time to sharpen.
View Grandpa's profile
Grandpa
3259 posts in 2582 days
#6 posted 09-22-2011 08:23 PM
Whe the wood is difficult or more difficult than normal to feed into the machine, the machine will start trying to lift the wood off the table. This is what a DULL blade will be like. Sounds to me like you should be gathering the price of a blade sharpening. I think you will like the results.
View bunkie's profile
bunkie
412 posts in 3054 days
#7 posted 09-22-2011 08:28 PM
Forrest did a very nice job resharpening my WWII. I, too, wondered why I waited so long after getting it back.
-- Altruism is, ultimately, self-serving
agallant
#8 posted 09-22-2011 08:43 PM
I am about to start a new project in a few weeks so I think I will try to clean and if that does not work then I will send it out.
-AG
View pintodeluxe's profile
pintodeluxe
5568 posts in 2720 days
#9 posted 09-22-2011 09:00 PM
I recommend simple green purple if you want to clean your blades. It is the purple green that is a purple liquid, and sells for about$13 per gallon. Dilute it 50/50% with water and watch that pitch and resin melt away. Sipmle green purple will not weaken carbide, and is approved for soaking. I clean my T.S. blade every couple hours of run time. Works great.
On a side note, how do you know when you only have one coffee filter? Feels like one, but what if it really two?
View SnowyRiver's profile
SnowyRiver
51457 posts in 3387 days
#10 posted 09-22-2011 09:48 PM
To add further comment, you will also experience the hard to push syndrome if your table on the saw has pitch or resin on it. It is difficult to see, so I frequently clean and wax the table and fence….you would be surprised at how much difference that makes.
-- Wayne - Plymouth MN
