Tuba mouthpiece
« back to Woodturning forum
Forum topic by kmetzger posted 01-12-2019 10:12 PM 355 views 0 times favorited 9 replies Add to Favorites Watch
View kmetzger's profile
kmetzger
160 posts in 2058 days
01-12-2019 10:12 PM
I’ve had an unusual request to make some tuba mouthpieces out of cocobolo. To shape the inside of the mouthpiece correctly, I need to make a mold. What material could I use to make the mold? https://www.youtube.com/watch?v=7-1td5f18QU at 1:07
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
9 replies so far
View TheDane's profile
TheDane
5576 posts in 3904 days
#1 posted 01-13-2019 12:29 AM
Bondo (auto body filler) might do the trick … just wax or lube the inside of the medal mouthpiece first.
View knotscott's profile
knotscott
8183 posts in 3616 days
#2 posted 01-13-2019 01:08 AM
FYI…Cocobolo is not skin friendly. I would think it’d be a terrible material to use as a mouthpiece.
Allergies/Toxicity: Notoriously allergenic. Reported as a sensitizer; can cause skin, eye, and respiratory irritation, as well as nausea, pink-eye, and asthma-like symptoms. See the articles Wood Allergies and Toxicity and Wood Dust Safety for more information.
View Kaleb the Swede's profile
Kaleb the Swede
1881 posts in 2210 days
#3 posted 01-13-2019 02:36 AM
Is this just for display or something? I am a tuba player too and am just wondering what the thinking is.
Couldn’t think of any reason to have one out of wood.
Not trying to dissuade you at all, just wondering
-- Just trying to build something beautiful
kmetzger
#4 posted 01-13-2019 03:45 AM
Here’s how one tuba player explains it. https://www.youtube.com/watch?v=BOKHwIk1KRM
And another one: https://www.youtube.com/watch?v=lbtV_PExlfI
View John Smith's profile
John Smith
1554 posts in 403 days
#5 posted 01-13-2019 02:45 PM
Kim, I second the auto body repair putty “Bondo” for the pattern.
or – whatever similar product you can find in your area.
liquid epoxy would work also if you can control the exothermic heat
generated by the product you use.
I harvested some Grenadilla wood when I lived in Guantanamo Bay
back in the ‘70s which is used exclusively for wind instruments such as the clarinet.
very easily turned on the lathe. does not hold an oil finish very well.
if you can find some in your area, I would recommend Grenadilla over cocobolo.
(and I think the Grenadilla is much more health friendly than the Cocobolo).
for examples, google: Grenadilla Wood Mouthpiece
-- I started out with nothing in life ~ and still have most of it left.
John Smith
#6 posted 01-13-2019 05:02 PM
Kim – looking at your very nice projects, I would assume that you have
some two-part epoxy on hand. . . .
you could turn a piece of wood to fit 1/8” loosely inside the mouthpiece,
plug the hole in the stem of the mouthpiece with tape, use a “mold release”
with whatever you feel comfortable with, and pour in some epoxy and insert
the wood plug until the epoxy cures. that way, there is less epoxy used
and practically eliminates the exothermic heat that could jam everything up.
also provides more “hand hold” to twist it loose after the cure.
(seal the wood first to prevent it from soaking up the epoxy).
kmetzger
#7 posted 01-13-2019 06:36 PM
Thank you for this, John. Everything is clear except for “mold release.” How do I pour the epoxy into the cup of the mouthpiece?
John Smith
#8 posted 01-13-2019 06:53 PM
mold release is any product that will form a barrier film between the epoxy
and the item it is poured into so it won’t stick. a layer of wax, spray silicone,
cooking spray, vaseline, etc. will work.
if you can melt some candle wax, that will work best. (just keep it as thin as possible).
a thin film of wheel bearing grease will also work ( just a little harder to clean up).
some people have used automotive and furniture paste wax, but, I have had some
bad issues with that. drill a hole in a 2×4 to keep the piece firmly vertical.
tape some paper around the top just to keep everything neat and tidy.
remove any bubbles then insert the wood plug, keeping it centered as much as possible.
put some weight on top to ensure it doesn’t try to float up.
the excess epoxy will flow out onto the paper. let it cure for at least 6-8 hours.
then twist it apart, clean off the mold release and you have your pattern to copy.
if you are going to be doing several of these, I would annotate the mouthpiece number
on the wood for future reference. (there are different sizes for different tones).
View Lazyman's profile
Lazyman
2708 posts in 1628 days
#9 posted 01-14-2019 12:58 AM
I don’t think that I would want to risk having to clean bondo off of someones mouthpiece. Since it is designed to permanently stick to metal, that could be a nightmare to clean off. In fact anything that needs a release agent would worry me. I would look at the modeling clays at a craft store like Michaels or maybe Crayola Air-Dry Clay; preferably, something that is water soluble. At a minimum, experiment with some old silverware or something with a nice silver or nickel finish on it to make sure that you don’t ruin it.
