First Plane
« back to Hand Tools forum
Forum topic by sawneck posted 01-12-2019 06:36 PM 326 views 0 times favorited 19 replies Add to Favorites Watch
View sawneck's profile
sawneck
46 posts in 3395 days
01-12-2019 06:36 PM
Ok I got the sharpening stuff nailed down and i am all set, got my honing guide now I need to decide on a single LN plane as a starter. So far I am considering the following in order:
1)Rabbet plane (seems like this is two tools in one more versatile)
2) LN # 102 block plane
3) #62 LA Jack plane
4) #601/2 adjustable mouth block plane
Any and all input would be appreciated..Work being done will vary, mostly larger furniture pieces and as of right now seems like alot of shop jigs.
Thank you!
19 replies so far
View Smirak's profile
Smirak
78 posts in 759 days
#1 posted 01-12-2019 06:40 PM
Just my two cents, but I wouldn’t consider the rabbet plane as the first purchase. From your list above, and the limited amount of information that you gave about what you’d want/need a plane for, I’d go with the LA Jack.
View Andre's profile
Andre
2372 posts in 2047 days
#2 posted 01-12-2019 06:55 PM
What do you intend to build, Tables, LA Jack. Small Boxes 102.
My first LN was the Brass 102, later got the 60 1/2 rabbet and some brass Spoke Shaves.
You can use the 102 on almost anything the LA Jack not so much?
While in principal the 60 1/2 and the Rabbet plane are the same plane after some time in your hand
you find they are slightly different and I seldom reach or look for the Rabbet plane when I need a block plane?
View waho6o9's profile
waho6o9
8539 posts in 2817 days
#3 posted 01-12-2019 07:00 PM
A LN #5 with a 50 degree frog works wonders.
View jonah's profile
jonah
1974 posts in 3539 days
#4 posted 01-12-2019 07:11 PM
I firmly believe everyone’s first plane should be a block plane. I’d get the 60 1/2.
View Johnny7's profile
Johnny7
411 posts in 1331 days
#5 posted 01-12-2019 07:33 PM
For your very first (and only) plane …
The answer is a standard (#5) jack.
There’s a reason it’s been nicknamed the “jack” plane—it’s the “Jack-of-all-Trades”
Not sure where your original list came from, but this plane should top it. It can be used for roughing, scrubbing, smoothing and, within reason, jointing.
The LA Jack, while a fine tool, is a specialized plane—one you can add to your arsenal at a later date.
sawneck
#6 posted 01-13-2019 02:31 AM
There s a reason it s been nicknamed the “jack” plane—it s the “Jack-of-all-Trades”
- Johnny7
Thanks..The list came mostly from my own research, some folks I respect and my own thoughts..to be honest I read Marc Spagnuolos book and he recommended skipping the 601/2 and getting the rabbett block plane because it’s two planes in one can be used as a standard block and to work tenons etc.
It’s funny you mention the standard #5, since he speaks highly of that plane too, but said for a first plane it’s takes more to set up and adjust so the LA Jack may be the better choice. Not that he is the last word but LN also recommended the LA Jack as my first plane since it’s good for flattening and many other larger plane tasks.
What about the 102 combinined with a #5? Standard or LA seems like it would be versatile for small and large workpieces/tasks.
Thanks again for your help.
sawneck
#7 posted 01-13-2019 02:33 AM
- waho6o9
Can it flatten large boards without too much fussing ?
sawneck
#8 posted 01-13-2019 02:39 AM
- Andre
Yes, first large project will be a slightly dumbed down Roubo..But also some small furniture, shaker table, a book case, and whatever else sparks my interest. But those are on the horizon near term. That little 102 seems like a nice plane for little every day tasks. For example I needed to flatten a small piece of maple for a shop jig would have been nice to have a plane, ANY plane actually. Instead used my belt sander for a reference edge then my planer from there.
Funny the 62 is not a highly regarded plane here on LJ, everyone else I speak to seems to think that plane is the end all be all plane.
Andre
#9 posted 01-13-2019 04:33 AM
- Andre
- sawneck
62 actually very good choice as first large plane, my preference would be a Veritas with PMV-11 iron!
All my first bench planes were Stanleys which I tuned and swapped out the irons for PMV-11
Seeing as I live quite close to a Lee Valley the Veritas planes were much easier and cheaper to obtain, PMV-11 irons made the choice a no brainer.
View CaptainKlutz's profile
CaptainKlutz
717 posts in 1735 days
#10 posted 01-13-2019 07:03 AM
Another hand plane debate about personal choice, so much as been posted already:
http://lumberjocks.com/search_results?q=first+plane
This blog has a good summary on picking first plane:
http://lumberjocks.com/OSU55/blog/39841
and then your second one:
http://lumberjocks.com/OSU55/blog/39842
Remember that as soon as you get one hand plane and have experience;
you will develop a personalized purchase priority list, regardless of what you read on WWW. :-0)
Good luck on your decision!
View anthm27's profile (online now)
anthm27
548 posts in 1351 days
#11 posted 01-13-2019 10:44 AM
Do yourself a favour and get a low angle smoothing plane from Lee Valley.
Low angle why?? We use chisels bevel up, why wouldn’t we use hand plane blades bevel up?
Just my 2 cents worth.
http://www.leevalley.com/us/wood/page.aspx?c=&p=45864&cat=1
Regards Anthony
waho6o9
#12 posted 01-13-2019 12:26 PM
Yes.
I flattened the workbench my plane’s sitting on without tear out and it turned out great.
sawneck
#13 posted 01-13-2019 12:34 PM
Low angle why?? We use chisels bevel up, why wouldn t we use hand plane blades bevel up?
Regards Anthony
- anthm27
so why not a low angle jack instead?
View knockknock's profile
knockknock
466 posts in 2414 days
#14 posted 01-13-2019 12:55 PM
Regards Anthony
- anthm27
Interesting concept, I started with a LV/Veritas small bevel up smoother
Because it could do the same functions as a block plane (although one hand usage is clumsy and not realistic), and be used as a smoother for the faces of boards, flushing dovetails, and shooting. If you are only ever going to get one plane, the small bevel up smoother makes a nice gentleman’s plane. Or in the longer run it is a nice small and light bevel up bench plane.
View Don W's profile
Don W
19050 posts in 2808 days
#15 posted 01-13-2019 01:43 PM
We all do things differently, build different things and work in different ways.
Personally I can’t see a jack as a first plane and definitely not a rabbet. For a first bench plane a #4. A good block plane is a must.
https://www.timetestedtools.net/2016/01/26/what-bench-planes-do-i-need/
