Heating my shop
Forum topic by HardKnockCarpentry posted 01-12-2019 04:34 PM 576 views 0 times favorited 23 replies Add to Favorites Watch
View HardKnockCarpentry's profile
HardKnockCarpentry
14 posts in 16 days
01-12-2019 04:34 PM
My shop is about a 20×25 space. It is not currently insulated, but is cinder block for the walls, and I could easily insulate the ceiling, between the joists. I am currently wondering if I should buy a wood burner heater, or just get some space heater, that is either infrared, or I can keep on 24/7, to keep the shop nice and toasty. Any ideas / thoughts are greatly appreciated.
23 replies so far
View TravisH's profile
TravisH
642 posts in 2176 days
#1 posted 01-12-2019 05:17 PM
Seeing you are in Indy temperatures aren’t that bad in regards to extremes and length of those extremes.
Personally insulation would be on my list of must do. Several ways to go about it and several basically just slight different way of doing similar.
Personally I would roll the walls with some Drylock paint first. Just as a precaution and especially in no siding just painted block on exterior. Attach 1 inch rigid foam to the wall, seal gaps wtih expanding foam and tape seams.
Then frame up a wall and insulate with batting, cover with vapor barrier then slap your wall material on.
You can run furring strips and rigid foam panels between (layered to get desired R value), foam the gaps, etc..
I would also look at insulating above also. No need to heat dead space. Will be much more comfortable year round and save you money especially if you are talking about running 24/7. Heating go with what you like.
View BoilerUp21's profile
BoilerUp21
111 posts in 1008 days
#2 posted 01-12-2019 05:31 PM
Not sure if you have natural gas connection available, but i just put one of these https://www.farmandfleet.com/products/940364-dyna-glo-blue-flame-vent-free-dual-fuel-wall-mount-garage-heater.html in my insulated garage and it runs very little and keeps the garage at 60F 24/7 on its lowest setting.
View Matt Hegedus's profile
Matt Hegedus
147 posts in 1034 days
#3 posted 01-12-2019 06:27 PM
I’m in a similar situation, but they’re wood walls, zero insulation, and a few little holes thru which I see daylight.
I tried kerosene and electric heaters for my 20×21 space. So far, the absolute fix for this came as a surprise:
My dad bought me one of those stand up propane heaters you see outside of nightclubs. Where the burner is 7’ in the air. Couple it with a fan and your problem is solved. You can buy those heaters for $100 now, and one full grill sized propane tank lasts me about 20+ hours on half heat.
I’m literally sweating in one hour. Try it!
-- From Pittsburgh, PA
View WoodenDreams's profile
WoodenDreams
379 posts in 151 days
#4 posted 01-12-2019 06:28 PM
I have Central Air (heat & A/C) in the shop. I do have Air Filtration System, but it still blows the wading dust and have to change the furnace filters more often. Hence, I don’t use it. So I installed Cove Heaters (radiant heat). This heats the objects and floor in the shop. In turn the objects heats the air.
HardKnockCarpentry
14 posts in 16 days
#5 posted 01-12-2019 06:32 PM
Awesome. Yes my house is basically all gas. I would have to run a gas line out there, but shouldn’t be that tough to run. Thanks guys.
HardKnockCarpentry
14 posts in 16 days
#6 posted 01-12-2019 06:35 PM
- BoilerUp21
Wonder if it’s safe(ish) to leave this on, unchaparoned. Or does it have a thermostat, or just stay running?
BoilerUp21
#7 posted 01-12-2019 07:13 PM
- BoilerUp21
Wonder if it s safe(ish) to leave this on, unchaparoned. Or does it have a thermostat, or just stay running?
- HardKnockCarpentry
Controlled by thermostat and has oxygen depletion sensor. Stumpnubs did a review on them and they are perfectly fine for shop use. Wish i had done it sooner.
View Design59's profile
Design59
11 posts in 11 days
#8 posted 01-12-2019 10:33 PM
Wood Stoves have a tendency to dry out the air more than gas or IR space heaters. I would just insulate really well and use either gas or IR. Everyone I know that use wood stoves have problems with splitting in the winter time.
-- Table leg and Component Vendor, NC, https://www.design59furniture.com/
View ohtimberwolf's profile
ohtimberwolf
882 posts in 2593 days
#9 posted 01-12-2019 10:52 PM
Be careful to not create a double vapor barrier it will trap moisture
Also any un-insulated area will become a heat sink (hot spot) and you will lose heat there. larry
Also see this.
https://www.google.com/search?q=do+propane+heaters+give+off+moisture&oq=do+propane+heaters+g&aqs=chrome.1.69i57j0l5.14649j0j7&sourceid=chrome&ie=UTF-8
-- Just a barn cat, now gone to cat heaven.
HardKnockCarpentry
14 posts in 16 days
#10 posted 01-13-2019 05:19 AM
My shop is already small as it is (25×20). I wonder if I should lose a tiny little bit of space, by studding out the exterior walls that are all cinder block, and putting in insulation / drywall.
ohtimberwolf
#11 posted 01-13-2019 02:04 PM
You would only lose about a 5×6 sqft of space doing that. Spread over the entire shop that wouldn’t mean much if it were my choice. Be sure to run plenty of outlets and lights unless you plan on surface mounts, even then still do so. I had to scale down to a single car garage shop but I still insulated my block walls as cinder block or concrete block walls are a huge heat sink. The difference in comfort with both heat and a/c is shocking with insulation.
larry
View Kelly's profile
Kelly
2189 posts in 3185 days
#12 posted 01-13-2019 02:22 PM
If I could afford it, I’d build with 2×10 walls for the insulation potential. I’m that much of a fan of insulation.
My shop 30×60, but I put a wall up for material and equipment storage (sprayers, ladders, wood, etc.) and parking a car, leaving me about 30×35. It was all uninsulated until the winter before last. With our hot summers and cool to cold winters, it wasn’t always comfortable working in it.
I added six inch to the walls and a first layer of 3-1/2 to the ceiling (until the wiring is the way I like it and more will be added). What a night and day difference that made. So much so, I suspect getting the sheet of rock on the other three walls and ceiling will be another HUGE jump.
As it is, I spend my days in the shop year around. A ceiling hung 5000/7000 watt heater makes it very comfortable out there when it’s cold. Once the rest of the attic insulation is in and all the rock on, I’ll probably just heat and cool it 24/7.
HardKnockCarpentry
14 posts in 16 days
#13 posted 01-13-2019 02:38 PM
You would only lose about a 5×6 sqft of space doing that. Spread over the entire shop that wouldn t mean much if it were my choice. Be sure to run plenty of outlets and lights unless you plan on surface mounts, even then still do so. I had to scale down to a single car garage shop but I still insulated my block walls as cinder block or concrete block walls are a huge heat sink. The difference in comfort with both heat and a/c is shocking with insulation.
larry
- ohtimberwolf
Yeah, we currently have a 3 car garage, with the original garage, being my shop, and it’s seperated by a cinder block wall, from the other 2 car garage. I’m about to kick my wife out of that side, and move the shop to the 2 car garage, as it is already sheet rocked and insulated. I don’t park in the garage, as my truck will not fit under the door. I will let you guys know how this goes with her, as the smaller garage, is a longer walk.
ohtimberwolf
#14 posted 01-13-2019 02:56 PM
Ha Ha. If she works and has to walk through your shop to get to the car I hope you have a long and happy life but I doubt it.
Putting up a stud wall with screws (so it can be taken down easily) in the bay that is next to your shop is not hard to do and the car is still where it is seperated but where it belongs. It may have some advantages having that second part separated (even if it is a bllock wall) from your dust making tools and can be quite nice when it comes to assembly and finish of your projects.
Give it a lot of thought (think about groceries and other things that must move from car to home) and realize that you will have to live with your decision for a long time. No one likes war in the camp! Especially a long war. There is nothing like a happy home. larry
View ibewjon's profile
ibewjon
80 posts in 3034 days
#15 posted 01-13-2019 06:09 PM
Yes, 1” foam on the walls, then 6” studs and fiberglass, or studs, electrical, then closed cell foam sprayed in. 12” in the ceiling, minimum. The savings on the heat will pay for the insulation. I only have a 16×24 x 10’ ceiling. But with 6” walls and 12” ceiling insulation, I can heat my shop with a 4 kw in wall electric heater, but now I have installed a heat pump that is 28 seer for the AC and 14 for the heat side. It is efficient down to -14 on the heating side, and I have meters installed to monitor energy use. It costs me about 25 CENTS a day to cool and 75 cents a day to heat here near Joliet IL. Insulation is the key, but $ buy the keys. 70 degrees winter and 74 summer in the shop.
