Laguna 14BX - Can I install the mobility kit with the saw standing up?
Forum topic by Ilan posted 01-12-2019 08:15 AM 681 views 0 times favorited 4 replies Add to Favorites Watch
View Ilan's profile
Ilan
17 posts in 844 days
01-12-2019 08:15 AM
My Laguna 14BX has arrived but the mobility kit hasn’t yet. I want to set it up but I don’t want to lay it down when the mobility kit arrives. Can I install it when the saw is standing up?
View Sawdust35's profile
Sawdust35
43 posts in 1102 days
#1 posted 01-12-2019 08:11 PM
Yes. I installed the mobile base on my 14bx with it upright. I raised the base off the floor with scrap wood and installed the kit.
View Ilan's profile
Ilan
#2 posted 01-12-2019 08:30 PM
Thanks. I am setting it up right now!
View Ilan's profile
Ilan
#3 posted 01-13-2019 03:03 AM
Hey, another question if you don’t mind, Sawdust.
I set everything up with one exception. While the table is perfectly square to the blade on the left and right side of the blade, it’s tilted backward .2 degrees (so it’s 89.8 instead of 90). I saw some instructions on page 50 in the manual on how to fix it but it seem really complicated.
Do you know a better way of squaring the table to the back of the blade?
Sawdust35
#4 posted 01-13-2019 03:59 PM
I think what page 50 describes is the easiest way to correct your issue. If you need to shim something use the sides of a beer/soda can. I had to read page 50 a few times, but it sounds like once this is adjusted it should ok for a long time.
