Is it okay to grain filling walnut veneer before glue up?
Forum topic by chris posted 01-12-2019 02:54 AM 163 views 0 times favorited 1 reply Add to Favorites Watch
View chris's profile
chris
5 posts in 518 days
01-12-2019 02:54 AM
Topic tags/keywords: box veneer grain filling laminating walnut mdf pore filling question
Im making this box from mdf and laminate it with walnut veneer on the outside and pvc sheet on the inside..i want to change the inside for the next box with walnut veneer also..but i find it will difficult to sand decently on the inside curve when grain filling. Can i grain filled the veneer before gluing it to mdf? (Tape it flat then grain fill it and then sand it)
1 reply so far
View MPython's profile
MPython
67 posts in 53 days
#1 posted 01-12-2019 04:35 PM
I have never done what you’re suggesting, so this is purely a guess. The curve of the box bottom looks pretty tight. My guess is that the filler wouldn’t tolerate the bending. You might want to do a test run to see how it fares. If it weren’t for the bend, I don’t think you’d have any problem with filling before the glue-up.
My $.02.
