bench dog router table / cabinet
Forum topic by Andrewbarbarian posted 01-12-2019 01:24 AM 259 views 0 times favorited 6 replies Add to Favorites Watch
View Andrewbarbarian's profile
Andrewbarbarian
17 posts in 97 days
01-12-2019 01:24 AM
I picked up a used bench dog router table / cabinet today. It came with an extra frame piece. I was wondering if anyone had an assembly Manuel. I couldn’t find one online. I don’t see where the piece goes.
Also I see the doors can be mounted on the lower level. Has anyone done this?
Andrewbarbarian
17 posts in 97 days
#1 posted 01-12-2019 02:13 AM
Was also wondering what these cost new?
View JRsgarage's profile
JRsgarage
337 posts in 750 days
#2 posted 01-12-2019 03:23 PM
Andrewbarbarian, I just checked but I can’t locate the instructions. Post a pic of the part and I can look on mine to see where it goes.
I think I payed around $500 with a Jessem Mast-r-lift and few attachments(featherboard, panel jig) from Woodcraft.
-- Two is One, One is None
View Mike_D_S's profile
Mike_D_S
557 posts in 2455 days
#3 posted 01-12-2019 04:05 PM
So I did some google magic and it took a bit, but I’m pretty sure these are the instructions:
https://images-na.ssl-images-amazon.com/images/I/81hG2Q7V3dL.pdf
I think the actual model is Bench Dog 40-007 ProCabinet Router Table Cabinet.
Mike
-- No honey, that's not new, I've had that forever......
Andrewbarbarian
17 posts in 97 days
#4 posted 01-12-2019 04:10 PM
Thanks mike. After reviewing the instructions its the “short support” that is not installed. It looks to me like if it is installed it blocks where the router hangs. Im assuming this is why the previous owner didn’t install it.
Mike_D_S
#5 posted 01-12-2019 04:53 PM
They made several different tops for that base. Some of them offered end mounting for the router lift. So instead of being centered, the router lift was off to the left or right and would fit on either side of the center support.
Check the short support piece. One of the steps in the instructions is to cut off a small piece of it to fill the holes in the back of the case, so you might see if they did that.
Heres a pic of one of the double lift tops where you would use the center support.
Mike
Andrewbarbarian
17 posts in 97 days
#6 posted 01-12-2019 05:39 PM
cool thanks
