Chisel Rack Plan request
Forum topic by Notw posted 01-11-2019 10:31 PM 236 views 0 times favorited 4 replies Add to Favorites Watch
View Notw's profile
Notw
679 posts in 1994 days
01-11-2019 10:31 PM
Does anyone have a copy of Woodsmith magazine #192, specifically the chisel rack listed below? I have more chisels than shows so the dimensions aren’t as important as the assembly.
View Phil32's profile
Phil32
359 posts in 144 days
#1 posted 01-11-2019 10:50 PM
It should be easy for you to make your own design. The vertical dimension must be high enough to keep the cutting edges off the lower frame. The horizontal dimension is a multiple of the space for the widest chisel. The spacing should allow you to grab the chisel handle without interference with the adjacent chisels. The slot widths must be slightly wider than the chisel shanks. Don’t over think this.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
View Notw's profile
Notw
#2 posted 01-11-2019 11:48 PM
Dimensionally I believe I’m good, my concern is more joinery, seems like based on the picture there would be a lot of end grain to long grain joints. So it makes me curious what I am missing.
View TravisH's profile
TravisH
642 posts in 2176 days
#3 posted 01-12-2019 01:33 AM
They first build the rectangular frame with half lap/rabbet joints. The top and bottom are then glued on followed by a solid back that ties everything together. The side corbels then are glued on.
View AlaskaGuy's profile
AlaskaGuy
5002 posts in 2550 days
#4 posted 01-12-2019 02:09 AM
That rack looka
a nice but it doesn’t look to be earthquake proof. In an earthquake the chisles with jump out and on to the floor pronto. DAMHIKT
