Table Top with Different Width Boards
Forum topic by cpbuck posted 01-11-2019 08:03 PM 208 views 0 times favorited 2 replies Add to Favorites Watch
View cpbuck's profile
cpbuck
14 posts in 431 days
01-11-2019 08:03 PM
Topic tags/keywords: maple joining milling
Hi all,
Are there any issues with making a table top with different width boards? The table will have breadboard ends.
I have some 6”, 8”, and 11” hard maple boards to make a table top out of. The table width will be 36” wide so my original plan was to use 6 – 6” boards. Seems wasteful to cut the wider boards down to width.
I have at least two of each width so I could use (2) 11” board + (2) 8” boards.
Thanks.
2 replies so far
View OSU55's profile
OSU55
2033 posts in 2230 days
#1 posted 01-11-2019 08:54 PM
No issues other than some may not like the non-symmetrical look. Its your table, its your decision. I would put the 11” in center and 8” outside. Cant envision an issue for the breadboards. Just space your tenons appropriately, which prbably means they are not centered on a given board.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#2 posted 01-11-2019 09:04 PM
11” wide boards are much, much more likely to warp than 6” boards. Breadboard ends help keep warping in check, but they don’t eliminate the issue. If your maple is flatsawn, it will be particularly prone to cupping across its width.
I think shooting for 6-8” width will be best.
Just lay the boards out and start trimming them one by one. The lumber will tell you what it wants to become, you just have to listen.
