Biscuits Thickness
Forum topic by bilyo posted 01-11-2019 03:42 AM 481 views 0 times favorited 16 replies Add to Favorites Watch
View bilyo's profile
bilyo
477 posts in 1343 days
01-11-2019 03:42 AM
I have a Craftsman biscuit jointer which, except for the handle on top, is identical to the Dewalt. I usually use biscuits for alignment purposes rather that strength. However, the biscuits I have on hand are a bit thin and, as a result, wiggle significantly when inserted into the slot. I know that the biscuits are supposed to swell when exposed to glue, but that doesn’t help much during glue-up and clamping to keep things aligned. Has anyone had experience with this problem? If I buy new biscuits, are there some brands that are consistently better fitting than others. I haven’t tried to “humidify” them to get them to “puff up”. Has anyone tried that? Don’t want to get them too wet.
16 replies so far
View GrantA's profile
GrantA
958 posts in 1648 days
#1 posted 01-11-2019 04:23 AM
I like mine about like this
Hehe sorry couldn’t resist. I don’t use wood biscuits much at all but I bet a little moisture (damp rag maybe) will fatten them up. Assuming you’re sure the cutter isn’t at fault – it could have a burr or be bent. The dewalt brand biscuits I recently bought were pretty snug when dry
bilyo
#2 posted 01-11-2019 03:55 PM
:>) (laughing quietly with a shake of the head) I was almost expecting that. At least, I wasn’t surprised.
I thought about the cutter after my post. I’ll check it today.
View ScottM's profile
ScottM
698 posts in 2387 days
#3 posted 01-11-2019 04:21 PM
I notice the same thing with mine. I have a biscuit jointer from HF. I also bought the biscuits at the same time. I then noticed how loose they were. I figured it was a HF thing so I bought another batch from Lowes and have the same problem. My next option will be to try a new blade. Maybe the cheap HF blade on it is too thick…
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#4 posted 01-11-2019 06:31 PM
The Dewalt brand biscuits fit a little tighter than other brands. There is even a notable difference between Dewalt and Porter Cable if you can believe it. I don’t think my experience is based on humidity changes, because all were sealed in plastic canisters.
I do think some play is helpful when assembling a project with glue.
View LesB's profile
LesB
1922 posts in 3683 days
#5 posted 01-11-2019 06:33 PM
“Maybe the cheap HF blade on it is too thick…”
If the blade is too thick and it has carbide tips that are wider than the disk why not grind them down a little. Yes, carbide is hard to grind so you may have to take it to a saw shop that sharpens carbide blades.
I have been using a Porter Cable for 20 years and never had a problem with undersize biscuits. If anything it is the other way around the biscuits which are compressed have expanded slightly in storage from ambient humidity and I has to sand them just a little. So I’m careful to keep the biscuits stored in an air tight container.
-- Les B, Oregon
View HokieKen's profile
HokieKen
7619 posts in 1379 days
#6 posted 01-11-2019 07:36 PM
It’s the biscuits. When I bought a jar of Dewalt biscuits, I noticed some joints were a little sloppy and others were pretty tight. So, I assumed the cuter was cutting inconsistently. Nope. Using calipers I verified that the slots were consistent. The biscuits, on the other hand, varied as much as .015”. Doesn’t sound like a lot but it is. These were all biscuits from the same jar mind you. So, now when I use biscuit joints, I use my caliper and select the exact biscuits I’m going to use before I start assembly.
Regarding the “humidification”, I find glue will swell them so if you use a glue with a long open time, you can coat the biscuits and insert them into one piece and wait a couple minutes before sliding the other piece on. Usually that’s sufficient to allow them to swell up for a tight fit. Never tried wetting them. I’d be afraid it would effect the bonding with the glue.
-- Kenny, SW VA, Go Hokies!!!
bilyo
#7 posted 01-11-2019 10:35 PM
I checked my biscuit jointer blade today. It is cutting a slot 4mm (5/32”) wide which is the standard, I believe. I am trying to put a sample of the biscuits in a very humid environment, without directly wetting them, to see if they will puff up. I’ll let you know. In the mean time, I’ll try some of the Dewalt biscuits.
View Kirk650's profile
Kirk650
585 posts in 989 days
#8 posted 01-12-2019 02:08 AM
Thin biscuits are not my problem. I have a high percentage of swelled biscuits, and would like to find a good way to get them back to the original thinness. I haven’t yet tried the microwave.
View Richard Lee's profile
Richard Lee
213 posts in 1015 days
#9 posted 01-12-2019 02:18 AM
Ive used the original Lamello biscuits for years and never had a problem.
View AlaskaGuy's profile
AlaskaGuy
5001 posts in 2549 days
#10 posted 01-12-2019 05:06 AM
I have just been retrained. Those so call ed biscuits are not biscuits at all. They are actually flat dowels.
https://www.youtube.com/watch?v=ThPEF7h5x2Y
View MSquared's profile
MSquared
146 posts in 155 days
#11 posted 01-12-2019 05:39 AM
Hmmmm …
-- Marty, Long Island, NY
View splintergroup's profile
splintergroup
2515 posts in 1463 days
#12 posted 01-12-2019 03:50 PM
I always had problems with the biscuits being too thick. I learned to test fit the biscuits before gluing. Fixes are a quick heating in the microwave or a simple whack with a mallet before installing. (these were all PC brand biscuits for my PC 557)
For thin biscuits, I’d use the wet with a damp rag trick. Glueing should not be affected, but they are only for alignment right?
View WoodenDreams's profile
WoodenDreams
379 posts in 151 days
#13 posted 01-12-2019 06:48 PM
#00, #10, and #20 biscuits are normally standard to size and thickness. You can always make your own. Take a scrap piece of hardwood, and slice a strip of hardwood to your thickness that your having a issue with, and cut to shape on a bandsaw. Would save you $6.00 on 85 #20 biscuits.
View steve104c's profile
steve104c
51 posts in 1479 days
#14 posted 01-12-2019 07:16 PM
Was watching a woodworking show on PBS. The so called “professional “woodworker was using biscuits in one of his projects and said that the biscuits were made from plywood. Stopped watching that program. I don’t know everything but I do know when someone is full of IT. The biscuits are made from thin pieces of beech and cut with a cutter like a cookie cutter w/ the size and sometimes the brand pressed into it. If you live in a humid area like I do, you need to keep them in a sealed container. Loose is better than too tight. They will swell when they absorb the glue. Be sure you have enough glue in the slot. Not all biscuit jointers are =. The blades can very in thickness and the different biscuits can also vary. Try leaving biscuits out and see if just the humidity will make them swell just a little. I don’t thank you should put them in water. Then the glue won’t absorb into them properly. Now if you’re using polyurethane glue, yes dampen the biscuits. You definitely would have to clamp and leave clamped for a longer period. Awfully messy too. USE A WATER BASED when gluing up panals( table tops,cabinet sides etc). Steve
bilyo
#15 posted 01-15-2019 02:15 AM
Thanks for all the comments. I just wanted everyone to know that I suspended one of the thin biscuits in a jar with about 1/4” of water in the bottom so that it was in a very humid environment (not directly wet). After about 48 hours, the biscuit had puffed up to the standard 4mm (5/32”). Of course, it then fit the slot with no slop.
