Any issues gluing up table top with center planks 4/4 stock and outer edge/breadboards 6/4 o 8/4?
Forum topic by SMP posted 01-10-2019 07:59 PM 684 views 0 times favorited 5 replies Add to Favorites Watch
View SMP's profile
SMP
178 posts in 146 days
01-10-2019 07:59 PM
I am going to build a kitchen island/table that will be about 8’ long and 3’ wide. Pricing out wood, 8/4 can get pretty expensive(Walnut), obviously 4/4 is much more affordable and plenty strong enough for the application. But I do like the look of thicker stock, either 6/4 or 8/4 around all the visible edges. This will also most likely have breadboards. I was just curious if there was any issue with gluing up say 6” planks with the 4 centers being 4/4 and the outer planks 8/4? I realize the glue up would be a little trickier, but mainly wanted to know if this would cause issues down the road.
Thanks!
5 replies so far
View HokieKen's profile (online now)
HokieKen
7619 posts in 1379 days
#1 posted 01-10-2019 08:24 PM
I don’t see any issues. Obviously you’ll need to use 8/4 stock for your breadboards but once they’re in place, you won’t be able to tell the center boards are thinner unless you get under the table and look for it.
-- Kenny, SW VA, Go Hokies!!!
View Steve's profile
Steve
825 posts in 823 days
#2 posted 01-10-2019 08:44 PM
somewhere there’s a link to an article showing where the guy took some 4/4 stock and then cut off a section at the end and flipped it underneath to give an impression of a thicker table.
View SMP's profile
SMP
#3 posted 01-10-2019 10:11 PM
somewhere there s a link to an article showing where the guy took some 4/4 stock and then cut off a section at the end and flipped it underneath to give an impression of a thicker table.
- Steve
interesting, I thought about doubling up the edge. But every time I have seen it doubled up it has an unsightly glue line and different grain/color, so cheapens the look. Even on some expensive tables I have seen. Haven’t considered cutting and flipping to see if it makes it look more like one piece. I suppose I can try with a scrap
View jtdon's profile
jtdon
18 posts in 747 days
#4 posted 01-10-2019 10:46 PM
I have made 2 dining room tables that I cut the edges all the way around and flipped glued and screwed to the top.
When the glue was dry I cut the edges all the way around at 45 degrees. You have to look really close to see the glue line using this method.
View Aj2's profile
Aj2
1953 posts in 2038 days
#5 posted 01-11-2019 12:30 AM
Making thick, someone might even admire your table for its top and heft then what. Aww it’s fake.
6/4 rough is a good thickness to start with.
-- Aj
