Biscuit jointers
Forum topic by Oldschoolguy posted 01-09-2019 02:08 PM 895 views 0 times favorited 42 replies Add to Favorites Watch
View Oldschoolguy's profile
Oldschoolguy
24 posts in 77 days
01-09-2019 02:08 PM
More than likely I will need a biscuit joiner for a project. What are your experiences using one? Brand names, reliability, and performance will also be considerations. I’m looking to spend somewhere between 200-300 dollars. All your recommendations and comments are always appreciated. Oh, and is there any difference between a biscuit jointer and a biscuit plate jointer? As always, thanks for your time.
42 replies so far
5242 posts in 2734 days
#1 posted 01-09-2019 02:20 PM
I had a Ryobi BJ for some time, and found it to be more trouble than it was worth. Trying to get the fence registered to 90° was a not-so-quick exercise. I went to a PC 557, and can’t recommend it enough for a biscuit joiner. To me a close second would be the Dewalt model. You won’t have to spend near that much on either as used show up frequently. If you opt for a used PC, look at the motor label and try to get a type 3, they had fence problems on some of the earlier ones that were fixed on the later models. Also, the PC came with 2 blades; one a very small one for FF biscuits…used ones are sometimes missing that blade.
View BlasterStumps's profile
BlasterStumps
1079 posts in 680 days
#2 posted 01-09-2019 02:29 PM
I use a router bit made for cutting biscuit slots. Works quite well.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Kirk650's profile
Kirk650
585 posts in 989 days
#3 posted 01-09-2019 02:38 PM
I have the Makita. It works great, but has one flaw. The chip discharge opening (to the bag) will plug off too easily. I’d buy the PC if starting over.
View pottz's profile
pottz
3847 posts in 1225 days
#4 posted 01-09-2019 03:09 PM
i have one and use it quite frequently.i just used it glueing up boards to make a table top,not for added strength but to keep the boards aligned.i started with the dewalt many years ago but then upgraded to a porter cable which i think is one of the best on the market today.very easy to use,good quality.i always hook mine up to a vac,if you dont it can clog sometimes.its a tool i wouldn’t be without,many will disagree though.
View knotscott's profile
knotscott
8183 posts in 3616 days
#5 posted 01-09-2019 03:12 PM
Had one for a few years early on, then realized it’s far from a necessity. Biscuits aren’t needed often, and when they are, there are several good methods for using them that don’t require a specialized biscuit cutter….router, TS, etc/
View GR8HUNTER's profile
GR8HUNTER
5400 posts in 953 days
#6 posted 01-09-2019 03:16 PM
in the cabinet shop we had a porter cable and it was a very good machine but when I bought 1 for home shop I bought a cheapo cheaponese now most time it just sits there :<)))
View RobHannon's profile
RobHannon
222 posts in 771 days
#7 posted 01-09-2019 03:17 PM
I have an older Dewalt and it is very easy to use and setup, but I almost never use it.
What are you using it for? Good chance you can accomplish the joint another way with tools you have and save the money for more wood. More wood justifies more projects that require more tools. Post the projects here and then we can get inspiration for more projects and more tools. Everybody wins.
View dhazelton's profile
dhazelton
2805 posts in 2537 days
#8 posted 01-09-2019 03:24 PM
I have an older Porter Cable and have used a friends newer Dewalt. Depth and bevel setup on the Dewalt was better. Would I sell the PC to upgrade? No – I don’t use biscuits enough.
View Holt's profile
Holt
280 posts in 2870 days
#9 posted 01-09-2019 05:28 PM
I bought the DeWalt simply because Porter Cable got into some kind of infringement problem and had to make a change that wasn’t all that great. The storm of what model types were good and bad and how to tell them apart was so aggravating that I punted and bought DeWalt.
-- ...Specialization is for insects.
View WoodenDreams's profile
WoodenDreams
379 posts in 151 days
#10 posted 01-09-2019 06:23 PM
I have the harbor freight brand. Cheap only paid $54 with coupon a couple years ago. Used it on about 30 projects, and had no issues. It’s not the same quality as some of the other brands, but saves money for other tools.
View Kazooman's profile
Kazooman
1270 posts in 2193 days
#11 posted 01-09-2019 07:14 PM
I think the Lamello is the gold standard, but it is more than double your budget. I have the DeWalt. It works just fine. The only issue with it is that it sounds like it is tearing its guts out when you fire it up. Still going strong, so I assume that is a “feature” and not a flaw.
View Rich's profile
Rich
4013 posts in 830 days
#12 posted 01-09-2019 07:14 PM
I bought the DeWalt simply because Porter Cable got into some kind of infringement problem and had to make a change that wasn t all that great. The storm of what model types were good and bad and how to tell them apart was so aggravating that I punted and bought DeWalt.
- Holt
What change did they have to make?
pottz
#13 posted 01-09-2019 08:16 PM
- Kazooman
yeah i had one,always sounded like a bearing was going bad-lol.
View JRsgarage's profile
JRsgarage
337 posts in 750 days
#14 posted 01-09-2019 08:19 PM
- Holt
I think the one to avoid was type 2 which were the ones right after the law suit. PC probably rushed in redesigning the fence
-- Two is One, One is None
View FreddieMac's profile
FreddieMac
147 posts in 588 days
#15 posted 01-09-2019 08:20 PM
I purchased the Ryobi plate joiner back in August for a computer desk project. I joined the top of the desk with it and did not have many problem. It was pretty easy to setup and use. I know plate joiners have a bad reputation, but I have had some success with mine since august.
showing 1 through 15 of 42 replies
