| Forum topic by a1Jim | posted 608 days ago | 1985 views | 1 time favorited | 46 replies | ![]() |
608 days ago |
Topic tags/keywords: question Hi friends My friend Charles Neil , is planing on making some DVDs just for Newbies problems like how to get your project done with what little tools you have. What we are looking for is what problems you have trying to do woodworking as a new woodworker . Thanks for you help -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
46 replies so far
#1 posted 608 days ago |
cutting twice and always too short!!! -- Bert |
#2 posted 608 days ago |
Hi Bert -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 608 days ago |
being absolutely sure that a power tool is set up 100% accurately to give the best results. Is there a good book out there that helps newbies to learn about maintenance and proper setup? |
#4 posted 608 days ago |
Sarahss I like Jim Tolpin’s “Table saw magic” Maybe Charles will address this in his new video too. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#5 posted 608 days ago |
I think that as a beginner it is challenging to know which wood to use for a specific project and also to make the most of the wood we have. -- Bert |
#6 posted 608 days ago |
I’ve got a router and a router table and have read several router books but not one has clearly explained how to safely and correctly install a router bit in a table-mounted router. As a result I have not yet tried routing anything – it’s the one tool in my shop that I’ve never used before except once in an already-set-up classroom setting. |
#7 posted 608 days ago |
One thing I struggled with (and still do to a small extent) is planning out what steps happen in what order. Preparation and planning seem to be about 50% of my build time (mostly free moments at night and work. I mean.. free moments at just night) -- Dan, Rochester, NY |
#8 posted 608 days ago |
Elizabeth Dan That’s a very good point too .Even as a seasoned woodworker I many times have to think that over for some time before going forward with a project. Good one Barry -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 608 days ago |
Jim, if it’s a one-off class it may be possible sometime; it’d be a 1.5 hour drive but I’ve done worse in the interest of pursuing hobbies! |
#10 posted 608 days ago |
how to build heritage furniture with just a screwdriver. -- Rob, Sault Ste. Marie, Ontario |
#11 posted 608 days ago |
Rob – Ripping boards to width might take a while ^_^ -- Dan, Rochester, NY |
#12 posted 608 days ago |
Although not a newbie, my current problem is in choosing the right wood for my upcoming project. I am building a model of a locomotive in 1-1/2” scale using mostly wood. There are many moving parts that must maintain clearances to operate smoothly. Think of a clock where the gears and levers must intertwine without binding. The dimensions of the wood I need to use are: 1-1/2” x 3/4”, 1” x 3/4”. I was thinking about poplar, red oak or even pine. The next requirement other than stability is price. I can rip and surface the material to my required dimensions, but it has to remain straight without warping, twisting, cupping, etc. It will be assembled with glue, nails and screws and painted. If you are familar with steam locomotives, you can see where; connecting rods drives the wheels, any deviation in the length of the rod will cause it to bind. I can maintain such alignment in steel, but it is hard to do in wood. I’m talking a few thousands of an inch tolerance. I’ve done this before in wood, but always had the problem of binding. I could set it up to run smoothly, but if the humidity changed, the works would bind, rendering the model as a static display, not an operating one. |
#13 posted 608 days ago |
I have a probelm cutting a decent miter. My table saw is over 30 years old and my chop saw is not accurate enough. Any suggestions? -- If you don't work, you don't eat!.....Garland, TX |
#14 posted 608 days ago |
#15 posted 608 days ago |
@Cozmo – Adjust it, fix it, or replace it, in that order. Seriously. I know you are not a newbie but that seems to be part of the problem with new folks, they don’t know they are using a bad or poorly set up tool. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15771 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2838 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
