When applying wax...
Forum topic by swampjack80 posted 09-21-2011 03:53 PM 1018 views 0 times favorited 3 replies Add to Favorites Watch
View swampjack80's profile
swampjack80
53 posts in 3073 days
09-21-2011 03:53 PM
I’m new to the whole paste wax thing so I have a question. I will be trying a danish oil/ paste wax finish. How many coats of wax should I put on after the danish oil? Also an answer I never seem to find in articles… When applying multiple coats of wax, should each coat be buffed after applying or do I apply a couple layers then buff them all at one time?
-- "I believe that our Heavenly Father invented man because he was disappointed in the monkey." - Mark Twain
3 replies so far
View jusfine's profile
jusfine
2422 posts in 2950 days
#1 posted 09-21-2011 05:35 PM
Usually that info will be on the wax container / label, as each product is slightly different.
I have switched to using Hardwax Oil, which I find gives me a better finish for my applications.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View chrisstef's profile
chrisstef
17423 posts in 3031 days
#2 posted 09-21-2011 06:06 PM
Ive used wax over Danish oil a bunch and i like the results. I typically put on 2 coats of wax buffing after each coat. Just make sure yu let the oil cure for a good 3-4 days before you hit it with wax.
swampjack80
#3 posted 09-22-2011 12:44 AM
Ok. Thanks. I mainly neededto know about buffing in between coats.
