New unscientific, but I'll expect nothing but honest answers poll
Forum topic by Betsy posted 594 days ago 288 views 0 times favorited 13 replies Add to Favorites Watch
Rockler
View Betsy's profile
Betsy
2386 posts in 796 days
594 days ago
how many of you knew that a coping saw is different from a fret saw. I, for one, did not. A fret saw is designed to do much more precise cuts and, if I’m not mistaken can use standard scroll saw blades. I’ll be pickng one up for doing dovetails.
View blackdogwoodshop's profile
blackdogwoodshop
71 posts in 628 days
594 days ago
I believe that a fretsaw is typically has a deeper frame than a coping saw and, as you suggest, is the hand-saw equivalent to a scroll saw. For dovetails in thin material, a fretsaw is probably a good choice. For thicker stock, I believe a fresaw might prove too tedious for me.
-- Daniel, Southern Indiana -- "Have nothing in your home that you do not know to be useful or believe to be beautiful." -- http://blackdogwoodshop.etsy.com
View Eric's profile
Eric
784 posts in 684 days
594 days ago
Hmm, I did know about the difference between the two but did not know that you could use a scroll saw blade in a fret saw. Look forward to checking out your work!
-- Eric at http://adventuresinwoodworking.com
View Lakey's profile
Lakey
99 posts in 672 days
594 days ago
Fret saws are a little easier to control – but then there are jeweler’s saws, which are usually more adjustable. Scroll saw blades can be a little hard to keep rigid, just so you know – I am still looking for the perfect combo to saw out dovetail waste. Good luck.
-- "No Board Left Behind"
Betsy
594 days ago
Thanks guys. I’m going to check out the fret saw and scroll saw blade combo and see how it works for me.
View Doug S.'s profile
Doug S.
307 posts in 608 days
593 days ago
I’ve got a couple of fret saws – one with a deep frame and one standard sized. I was under the impression that the difference was just the fact that the fret saws had the adjustable frames that let you use pretty much any blade that can be held in the top/bottom clamps (even short pieces of broken blades). And the coping saws needed the fixed sized pin end blades??
-- Use the fence Luke
Betsy
593 days ago
Doug – I’m getting the same general impression. However, the fret saw is apparently much easier to use simply because you can use any blade appropriate for the job.
View brunob's profile
brunob
1476 posts in 1069 days
592 days ago
I have one of each but don’t know which is which.
-- Bruce from Central New York
View motthunter's profile
motthunter
2079 posts in 699 days
592 days ago
fret saws have a deeper loop.. at least that is what I understand
-- making sawdust....
7696 posts in 1118 days
592 days ago
I saw the difference, but I didn’t fret about it. Now I’m coping with the consequences of my ignorance. :-)
View mot's profile
mot
4904 posts in 936 days
592 days ago
Yes, I also fretted about the availability of the two saws. Being unable to cope with the lack of availability of the fret, I fretted with an inappropriate use of the cope. After quitting fretting and giving up coping with my cope, I got a fret and fret no more. They are different. Just FYI, it’s actually easier to cope with a fret than to fret with a cope.
592 days ago
Sounds like a cop-e out to me, Tom.
View Texasgaloot's profile
Texasgaloot
467 posts in 600 days
592 days ago
Either one seems to be able to generate any number of puns…
I’m not sure, but I believe the fret saw originated to deal with the fancy fretwork one might find in, say, a Black Forest Cuckoo clock, whereas the coping saw is built a bit more rugged to handle coping trim work. Lately another form of fret saw has surfaced, used to cleanly cut fret slots in guitar fingerboards. I guess the difinition lies in the usage.
-- There's no tool like an old tool...
Betsy
592 days ago
You guys are a hoot!
Bruce and Moth——you can get fret saws in a three inch or 11 inch frame. And Texasgaloot is right. I’ve been looking a bit about these saws and they were designed for the finer scroll type work. Coping saws are more rugged, and I might add, for this gal hard to use.
