| Forum topic by SSMDad | posted 609 days ago | 964 views | 0 times favorited | 22 replies | ![]() |
609 days ago |
Topic tags/keywords: question chainsaw Ok while this technically has to deal with wood at some point, I still put it here to keep out of the way of more pertinent topics. I need a chainsaw to cut up logs to make turning blanks. I’m looking at either a Stihl, Echo, or Husqvarna. Does anyone have an opinion on these? I’ve heard from some that Stilh is the best made (and they are more expensive) but have had a acho trimmer that has never failed me in years. Not sure about Husq except they spend a lot of money to advertise. Thanks. -- Chris ~~Who controls the past controls the future. Who controls the present controls the past." |
22 replies so far
#1 posted 609 days ago |
i got the sthil and oil/gas caps that don’t get lost i’ve used huskys here is a good place to get chains $11 compared to $32 at the saw store i bought the saw at the sthil store -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#2 posted 609 days ago |
Around here most of the loggers use, Stihl! Usually Husq is the 2nd choice! |
#3 posted 608 days ago |
I have an Echo CS305 that I converted from 12in to 14in. I have used it over the past 10-years and am truly glad that I went with Echo this time. You can see my little saw in the background here. Years ago (late 1970s) I had a 20in Homelite that worked well enough, but I understand the Homelite has gone down ill since then. Also, a piece of advice—- Don’t let your ego make you buy larger than you need. I have found smaller is better, unless all you are going to do is cut down large trunks ALL THE TIME. I have found that I can do MUCH more with a smaller chainsaw without as much fear of kickback from sticking a long bar where it does NOT belong. ;-) Just my 2-cents… -- HorizontalMike -- "Woodpeckers understand..." |
#4 posted 608 days ago |
I’m engaged in a similar purchase decision myself. All I can really add is that when I moved to the country, I bought every landscaping thing I could think of with the exception of a chainsaw. I really didn’t care about the price at the time and I bought the best I could based upon recommendations. I bought the Husq brush cutter and starting abusing it right out of the box. It’s got the Honda that takes straight gas. I don’t clean it, rarely check the oil, and bang it around until it runs out of gas. It’s almost become a project of mine to kill it because they came out with a bigger one I want. I haven’t been successful over the last two years despite my best attempts. That gives me reason to look at the Husq chainsaws really hard. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#5 posted 608 days ago |
My husband collects chain saws. Mostly stihls and Johnsered. -- ----- www.KNWoodworking.com ----- -- |
#6 posted 608 days ago |
I’ve been using my sthil for over 25 yrs cutting a min. of 5 cords a firewood a year, other then bar & chains and until this past spring installing a new oiler the saw has been flawless. -- Doug... |
#7 posted 608 days ago |
I have an Echo CS340. 4 years old and have never had it worked on , it takes 3 pulls for a cold start and let it idle 30 seconds. Once warmed up starts first pull every time. Also have an Echo Leaf Blower and String Trimmer. Good prices and 5 year warranty -- He: Can I get the plans for that? Me: Plans??? |
#8 posted 608 days ago |
I own 2 husky’s and would buy them again. Here is what I use them for. It sounds like your not going to be cutting a lot (stihl, Husqvarna and Johnsered are made to run all day every day). If your only using it now and then, most known brands would probably be ok. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#9 posted 608 days ago |
I’ve had a couple echos and haven’t had a problem. I cut about 8 cords of pine a year. All machines noted above are great, but the price of the echo sold me. They also offer rebuild kits. Just as IMPORTANT is learning to sharpen the chains. I change out the chains often to insure a fast cut. -- Ron |
#10 posted 608 days ago |
I got tired of fooling around with mixing gas and having it sit around til it went bad. I just didn’t use it that much. -- Don't rollerskate in a buffalo herd |
#11 posted 608 days ago |
We like the Echo chain saw (CS-450 with 18” bar), brush cutter (SRM-265-T), and back pack blower (PB-500). All start easily and have had no problems but, do give them regular preventative maintenance. Have friends with Husky and Stihl that have same experience. Think you will be okay with any of the three. Good Luck! -- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas |
#12 posted 608 days ago |
Viking, how do you like that brushcutter? -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#13 posted 608 days ago |
Bertha; If I had to replace it would go buy same one. -- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas |
#14 posted 608 days ago |
^no kidding. I might have to look at the Echo a little harder. Husqvarna came out with a bigger “bicycle handle” style one after I bought mine. When I kill it, I wanted to go up a notch. I’ll take a look at the Echo. Thanks a lot, Viking. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#15 posted 608 days ago |
I’ve had and abused a Stihl for 36 years and it still runs strong. -- When the moderator chooses sides, his site sucks. |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15768 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
