I, like an idiot, didn't mix my poly before I put down the final coat and it resulted in an uneven sheen with 1/2 the floor looking like semi-gloss and half looking like satin.
your TinyPic link does not relate to your flooring issue. . . . .
(( possible SPAM here ))
as for the floor issue: you don't degloss it - you put on another coat of satin,
well mixed, over the entire floor.
Read, Understand and Follow the instructions on the label of all products you use.
Pay particular attention to the safety notes and heed the warnings accordingly.
any rags used in the prepping/finishing process that have paint, stain, solvents,
or oils on them, should be laid out in the open to completely air dry prior to discarding them.
improperly discarding rags that have wet oils and finishes on them could result
in spontaneous combustion that could result in a fire causing personal injury
or the total loss of your shop or home.
The link worked for me. I saw a photo of a wooden floor annotated showing the shiny and dull areas. What's with the rest of your lecture about reading instructions anyway? We have a new user who needs help and you're making accusations of spamming and talking down to them.
Back to the original post, Blentil, your best option is to get another can and mix it well. Don't try to just repair the glossy part. Chalk it up to experience and be happy with the fact that your floor will have an extra durable layer of protection
Yeah, John is a little harsh today. Must not have slept good. lol
Link worked for me.
Same advise as above, new coat would be easiest.
You could probably use a buffer with some kind of high grit screen to change the sheen,
but I have no experience to tell you what to use, so new coat for me.
yes - I totally agree that my server or net connection
has an issue with the site. I can only base my response with what I see.
and recoating a floor is an expensive lesson -
we all pay our dues in one way or another.
the pole sander used for drywall would make quick work
with scuffing - if you don't want to buy a new one, used
ones can be rented at the rental store or check your pawn shops.
Just be sure it's fully cured before sanding, or it'll clog your paper.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
