| Forum topic by blackthumb | posted 176 days ago | 221 views | 0 times favorited | 8 replies | ![]() |
176 days ago |
176 days ago |
Drill a hole and glue in a dowel, then drive your screw into that. Make the dowel as large as you can. -- Gary, East TX -- The longest journey begins with a single step. |
176 days ago |
Use confirmat screws, they’re designed for that purpose. -- www.DovetailDesignsNJ.com |
176 days ago |
the dowel works well for a tougher joint. I think the secret is to not overtighten it. Definately predrill and drive the screw by hand…..Trya screw with a big bite as well like a sheet rock screw or similar -- Soli Deo Gloria |
176 days ago |
Yes, the dowel idea sounds good. What about screwing into composition wood or particle board? |
176 days ago |
Drill a pilot hole and squirt in cyanoacrylate glue. It will provide a good grip. -- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...) |
176 days ago |
I don’t know if GaryK was referring to drilling a hole into the edge and inserting a dowel or drilling from the side and inserting a dowel. For me, the best way, if the project allows it, is to drill through from the side insert the dowel, drill a pilot hole and screw into the side of the dowel rather than the end grain. Either way will work but you get a lot more strength inserting the dowel so that you aren’t screwing into the end grain of the dowel. JimC |
176 days ago |
And be sure that you’re screwing perpendicular to the grain of the dowel too. -- Eric at http://adventuresinwoodworking.com |
176 days ago |
Yes, dowel from the side, how far in from the edge should it be? I imagine a half inch or more. |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1218 |
1643 |
118 |
331 |
103 |
Woodworking Trade & Swap
232 |
Coffee Lounge
913 |
LumberJocks.com Site Feedback
268 |
