Okay, so before you put me on blast, hear me out you strop die hard enthusiasts! I understand the point of a strop and compound and various leathers that may be better than others when stropping but, I've just heard about Shell Cordovan strops and that they're the equivalent of roughly a 10-12k grit. They're considered the pinnacle of stripping. But I am fortunate enough to own a Shapton Glass 16000 grit sharpening stone that puts a shine on my blades like nothing ever before. So after sharpening my hand plane blades on a 16000 grit stone, is it actually worsening my secondary bevel by stropping it on the equivalent of a 12000 grit stone (the shell cordovan strop) or is there something else in play here? I'm not even considering a compound on the shell Cordovan strop but my argument would change if the compound was greater than 16000 grit which is equal to 0.92 micron! I've yet to see a compound paste that small and then if I introduced the 30000 grit Shapton glass stone, if there exists a reason to strop, would it still stand?
I've also found stroping messes up a good edge but sometimes it make it better. So I dont strop very often expect my carving chisels. I also use shaptons pro stone.I even have the half micron 30,000 grit. Stone. Bought it from Hap some years ago.
Mostly I hollow grind and work from the stones.
Good Luck
I agree with Rich. The strop is for quick "refreshes" on the bench for me. I use it on freshly sharpened edges as well but I generally only sharpen to about 1500 grit. 6000 on paring chisels or carving tools. If your stone is finer than the strop or the compound on the strop, then no, I can't see any logic in using it personally.
Stropping is also known as honing and means you are aligning the edge without removing metal. Sharpening something requires you to remove metal to produce the edge. As far as you 16K grit stone goes, it's actually honing the blade, not sharpening. So yes, going down to a 12K equivalent grit means you're getting worse not better.
I use a strop but truthfully I don't think it makes a noticeable difference. I go to 8K.
I'll let the gurus correct me, but I think honing does actually remove metal. If its not, then what is the black material I'm seeing on my stone?
I'm of the belief there is the "dubbing effect" from over stropping or not doing it right, for example pressing too hard, or stroking to much. They way I figured this out was trying to follow Paul Seller's "30 strokes on the strop" idea. But then, he only sharpens to 1000 I think.
Then there's the question of which side of the leather goes up? And lots of people advocate a piece of MDF with compound rather than leather.
Bottom line if you're going to 16000 grit don't use a strop.
I use a horse hide leather strop on occasion. But for day-to-day stropping I have mounted 4 MDF wheels on a buffer/grinder. I shaped the wheels to conform to the rounds and V's of my carving tools.
I also put a leather belt on my delta 1" belt sander ($20 on Craigs). I charge the wheels and belt with my own green honing compound, made from beeswax. A few seconds is all it takes for my carving tools on the MDF wheels and my flat chisels on the belt.
My tools will go for many years without touching a stone, just stropping. Eventually the back gets rounded over a bit and I'll go back to the 1000--> 8000 diamond or Japanese stones. 8,000 is all I need for the finest work. Stropping does the day-to-day work and that is done in about 10 seconds when needed. The idea of doing 30 strokes each time would not be appealing!
Not having made the investment in high grit water stones yet, stropping definitely makes a difference for me. I use some lapping film from tools for working wood (the sample pack has lasted me quite a while now) and then I strop on leather with the green stuff. Out of curiosity I took some extra leather I had on hand and tried stropping on the smooth side of bare leather. Maybe a tiny improvement over leather and green compound, but sans water stones stropping is a necessity for me.
That's all great information. I just wanted to make sure I wasn't going crazy after finally accomplishing the task of getting razor sharp edges on my chisels, and hand plane blades by way of freehand. For those who still use a honing guide, I did for about 6 months until I wasn't getting the results that I wanted. I own the Veritas MK II Honing Guide and despite all of the bells and whistles and assurances that come packed in the box, I was constantly getting uneven bevel thicknesses which, I KNOW, does not make a difference when the cutting actually occurs. But, for an aesthetic purpose only, who would be happy paying the hundred plus dollars to take a brand new L.N. blade out of the packaging and then getting bevels that are very noticeably crooked? I've owned the Shapton stones for about a year now and I'd purchase them all again. I originally invested in some Arkansas sharpening stones but found that using oil all the time got to be messy and slippery.
I used the MK II honing guide for a while until I finally purchased an extra blade for my L.N. No. 4 and attempted to freehand sharpen it. The results were not only better than the MK II but the bevels are absolutely straight. It's imperative that you flatten your stones frequently between sharpenings if you want to get consistency on your blades.
So then I've heard all about stropping and the videos that I've watched of people sharpening knives and blades always finish the exercise by polishing the newly sharpened edge with a strop. When I discovered that the abrasive polish that is usually applied to the strop wasn't as fine as the 16,000 grit stone that I usually finish up with, I didn't understand the purpose. Besides, once you're done with 8000 (not to mention the 16,000), there's a reflection worth bragging about on the bevel so how could it get any better with further polish? I'll keep the "touch up" concept in mind when I'm out in the shop, I didn't consider that before. Glad I've gotten some perspective on the matter.
I use a horse hide leather strop on occasion. But for day-to-day stropping I have mounted 4 MDF wheels on a buffer/grinder. I shaped the wheels to conform to the rounds and V s of my carving tools.
My tools will go for many years without touching a stone, just stropping. Eventually the back gets rounded over a bit and I ll go back to the 1000--> 8000 diamond or Japanese stones. 8,000 is all I need for the finest work. Stropping does the day-to-day work and that is done in about 10 seconds when needed. The idea of doing 30 strokes each time would not be appealing!
I can strop no problem, but I like your idea here. It saves time and allows one to keep the angle correct more easily than a strop, unless one is really careful. Some of the people in my carving classes have themselves a time trying to strop their chisels. I see a lot of cutting edges rounded over from some long-term poor stropping. I'm thinking I could make something like this that people could use. Probably be some grinder work first, depending on the shape of the cutting edge.
Just scanned a sharpening supply retailer that I've used in the past and been happy with and to my amazement, found some "stroping" supplies that may enhance even a 16,000 grit sharpened blade. I'll attach a couple links, (I have no affiliation to this company, nor have I used any of the products that I'm posting). I'm simply attempting to add to the discussion that seemed to be over since I was not aware that there were stropping pastes/compounds or synthetic strops that exceeded a smaller micron size than 0.92 micron which is the equivalent of a 16,000 grit abrasive.
I haven't even considered purchasing the Shapton 30,000 (0.49 micron) stone because it is simply too expensive. I'm sure that the results are pretty amazing as I'm stunned with the quality of bevel I receive after the 8000 as well as the 16,000 grit stones. Considering the Shapton 30,000 stone retails for $360.00, I'm definitely considering the purchase of one of these synthetic "Jende Nanocloth Ultra Strops" that has an even drastically smaller micron size as small as 0.025 micron!!! That's absurd! Also, I've been probably misguided as many have about the micron size and the use of the word "grit". Apparently, a 0.5 micron abrasive is equal to 60,000 grit so however Shapton comes up with their numbers, I'm not sure. A 0.25 micron abrasive is equal to 100,000 grit so considering that there are synthetic strops available that have an abrasive as small as 0.25, 0.1, and 0.025 micron, perhaps my decision to skip the strop can be swayed. I'm going to contact this online retailer to inquire more information about these items and what kind of results can be expected.
Obviously, if you've used one of these Jende Nanocloth Ultra Strops, I'd love to hear about it.
There seems to be some confusion according to the results I've read on Google regarding micron size and grit size but nonetheless, there appears to be a sharpening abrasive out there capable of polishing your bevel at an equivalent of 600,000 grit! It must be like hand planing with a laser beam!
I posted this over on Rick M's Hot Deals thread, but it fits in here too. Popular woodworking is running a 14 day free trial for their video library.
Why does that fit in here? One of the videos in the library is called The Perfect Edge and it's hosted by Ron Hock, of Hock Tools. They make replacement blades for popular planes, etc, and Ron is considered to be one of the top authorities on steel and sharpening. He also wrote a book by the same name. In the video he does a superb job of explaining different steels (O1, A2, etc) and the theory and practice of obtaining the perfect edge.
Considering that you can sign up, watch that and however many other of their quality videos you can in 2 weeks, then cancel not owing a dime, it's a pretty good deal.
I actually just purchased that book but haven't read it yet. I've read about 20 pages so far and there's a ton of detail (all the way down to the molecular structure of various alloys) in just the portion that I read. I'm excited to read more about it as it seemed like the "Bible of Sharpening" considering Ron Hock has devoted over 400 pages to the subject. I've looked at the end of the book as well and electron images of many many stones and how coarse or fine they "actually" are for comparison-sake.
I'll update this again when I find out more information from sharpeningsupplies.com regarding those Nanocloth Ultra Strops. It appears there's a special emulsion that you would use with those strops as well that looks to be somewhat pricey. Not sure how pricey it is however because I don't know how long a small bottle is capable of lasting.
There seems to be some confusion according to the results I ve read on Google regarding micron size and grit size but nonetheless, there appears to be a sharpening abrasive out there capable of polishing your bevel at an equivalent of 600,000 grit! It must be like hand planing with a laser beam!
A 600,000 grit polisher is useless. Not trying to be a jerk, I'm just saying that we're talking about wood tools, not precision metalwork for Tony Stark's armored suit. You simply don't need to go crazy with sharpening.
I have an 8K stone that I use with chisels when doing very fine work. I'll also use it with my smoothing plane blade. Otherwise, 8K is overkill. Actually, it's overkill when I do use it. Honestly, I cannot tell a performance difference after ending with a 1K stone or an 8K stone. The only reason I use the 8K stone is to justify the purchase of the 8K stone. How many woodworkers 200+ years ago commonly used 8K stones or the equivalent? Basically zero, unless there was some natural stone that was crazy fine that I don't know about. I believe even the finest Arkansas is closer to 1K than 2K.
When I use different steels, that's when I can tell the difference between how long an edge lasts. Otherwise, after a certain point in sharpening, you are getting into diminishing returns. Too many people add too many steps (not just at the end, but on the gradual progression up the grit scale.) Once I've got the primary bevel established, I re-sharpen with 1-2 stones. That's it. I have an emergency room bill and empty band-aid boxes and nice furniture to prove that's more than sharp enough.
Possibly some shop made lapping plates of some sort a machinist made and used cow. I've seen similar contraptions in shops.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
