Norm Abram's favorite finish for Cherry
Forum topic by teenagewoodworker posted 591 days ago 2611 views 3 times favorited 14 replies Add to Favorites Watch
teenagewoodworker
2482 posts in 665 days
591 days ago
Topic tags/keywords: question cherry finishing
I saw a New Yankee Workshop episode about a month ago where he made something out of cherry and he did a beautiful finish on it. I think that this is it but i just wanted to check and see if anyone could recall it:
amber shellac
dark mahogany stain
poly
Just wanted to see it anyone could recall this finish so i can make sure that i have the right one (if i even do). I want to build something out of cherry and i want it to be darker to match the woodwork in my room. i chose cherry because that is the only hardwood at my lumber yard besides mahogany which is too expensive, maple which won’t stain well, poplar … no, or oak and i don’t want to go on a pore filling expedition right now. so any help would be appreciated.
View BarryW's profile
BarryW
872 posts in 803 days
591 days ago
He made a large mahogany table and used (I think) the finishes you are talking about….was it the table? I have most of the shows recorded on my DVR and could review it for you. Let me know. (When I saw this show I knew I couldn’t even afford the wood to make such a table let alone follow the instructions…and this show is for the average guy? he must have used thousands of dollars in mahogany…thousands.)
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
20732 posts in 718 days
591 days ago
This isn’t necessarily the only finishing process that Norm has used on cherry but here is one sequence:
- apply an amber stain, dry
- wipe on thin coat of sealer, dry
- knock down with 3/0 steel wool
- apply glaze: brown mahogany pigment in dispersion oil
wipe off excess with fresh rag going along the grain
dry overnight
- knock down again with 4/0 steel wool
- apply several coats of wipe on satin polyurethane, drying between each coat
This is an attempt to mimic aged cherry.
Another recommended process that Norm has used on his show is simply putting on Danish oil and letting the cherry age naturally.
I generally wipe on Danish oil, let it cure and top coat with poly. If I want to add an amber coloring to the cherry I will put on a 2 lb cut of amber shellac before adding the topcoat.
Hope this helps.
teenagewoodworker
591 days ago
Hey barry i think that i was a table now that you mentioned it. i thought that it was cherry but it might have been mahogany though.
teenagewoodworker
591 days ago
thanks to you too Scott. i think that i will go with that finish. we have cherry cabinets in my kitchen and they aren’t that old but i really like that look of them and a little browner from aging (what the finish should do) will be perfect for me. thanks!
View lew's profile (online now)
lew
4495 posts in 652 days
591 days ago
Dennis,
Scott has it nailed. I recently watched the episode on a corner chair and this is what he used:
- Light brown stain, let it dry
- Coat of shellac, dry, knock down with steel wool
- Brown Mahognay gel Stain, wipe off to blend, dry
- Several coats of Poly
Lew
View John Gray's profile
John Gray
1754 posts in 782 days
590 days ago
You can darken/age cherry in the sun and just use clear finish on it. Link to info: http://www.woodworking-magazine.com/blog/Tanning+Beds+The+Final+Frontier+For+Finishing+Cherry.aspxk YOU’ll PROBABLY HAVE TO CUT AND PASTE THE LINK or just go to http://www.woodworking-magazine.com/ and look it up under the finishing blog.
View Chris 's profile
Chris
1469 posts in 888 days
590 days ago
Great post and great info guy’s!
Especially since finishing is not one of my strong skills. This will be marked as one of my favorites.
-- Chris
View Joey's profile
Joey
259 posts in 712 days
590 days ago
I work with cherry all the time. The easiest way to “age” it and get the darker reds and browns is just to leave it out in the good old sunshile until it gets to the color you want. Just make sure you turn it every so often so it gets an even tan. I’ve always heard that 8 hours of direct sunlight is about 1 years age.
-- Joey, Magee, Ms http://woodnwaresms.com
teenagewoodworker
590 days ago
thanks for the advice everyone. I think that the best way to age it would be to leave it out in the sun. Thanks for the tips!
25803 posts in 1297 days
590 days ago
good luck.
View Texasgaloot's profile
Texasgaloot
467 posts in 597 days
589 days ago
I’ve often used 2 parts boiled linseed oil to 1 part turpentine, wiping a couple of coats on, then adding the clear coat of your choice: a high quality (Epiphanies) spar varnish or poly. I have a shaker end table finished in this manner a couple of years ago (I’ll post photos after I borrow a digital camera) and it has darkened very nicely. The sun will, in fact, do the job better than any stain can, because the grain and any flaming looks much deeper. On the other hand, if you leave a little sapwood in there (as I did because I was stingy with my expensive wood) it can rather scream at you. Word to the wise.
-- There's no tool like an old tool...
View HarleySoftailDeuce's profile
HarleySoftailDeuce
154 posts in 316 days
122 days ago
I’m building kitchen cabinets as my first woodworking project, and am not sure how to finish the cherry face frames and doors. Anyone have recommendations?
Paul
-- Paul, Bristol,Rhode Island
View GuyK's profile
GuyK
142 posts in 976 days
122 days ago
My favorite Cherry finish.
First use a mix of 50% Zinners Sealcoat with 50% Denatured Acohol ( this will stop the bloching assoiciated with cherry ). Sand after dry with 320 grit ( hand sand preferred )
Then apply General Finishes Black Cherry. I know some don’t like to stain cherry, but this stain gives a near instant aged look and is it easy to control the color.
Then apply the topcoat of your choice.
I have also seen Norm use a poly stain mix on Cherry. ( the Martha Washington Candle Table )
-- Guy Kroll
View Damian Penney's profile
Damian Penney
1030 posts in 888 days
105 days ago
For aging cherry you can slap on some potassium dichromate – boom – instant age.
