New 10" RAS - well almost new
Forum topic by dbray45 posted 612 days ago 912 views 1 time favorited 26 replies Add to Favorites Watch
View dbray45's profile
dbray45
2018 posts in 947 days
612 days ago
I bought this beast over the weekend from a coworker. He had this sitting in the back of a storage locker.
After downloading the owners manual, it was time to dissassemble a bit so I could carry it down the stairs. Manuals are a good thing, they tell you how it goes together before you break it. As it turns out, this was made in 1970 and was pretty well maintained. The guy I bought it from never turned it on, so he tells me, so any maintenance was the previous owner. THe bearings are in good shape, the board is original with the adjustment holes. It is not going to need a lot of work, have to get a key for it and I may replace the power cords – just because. For $150, I couldn’t pass this up. Sears still sells the keys for this – go figure.
Now I have to rearrange my entire basement and build a work bench for this – is is a heavy piece of equipment. Darn mouse has a really BIG cookie.
As a note, I was thinking of getting a new miter saw (gave my old one to my daughter), but the new ones require so much space behind them that it would have been a space problem as well.
Any of you out there have one of these and have any recommendations?
Thanks for looking
-- David in Damascus, MD
26 replies so far
View tenontim's profile
tenontim
2129 posts in 1914 days
#1 posted 612 days ago
NIce find. I started out with a RAS and sold it, then recently bought another. Mines an ‘80’s model. Don’t know how I did with out it. Check out this site http://www.radialarmsawrecall.com/ some of the Craftsman saws were on the list for a recall. If yours is on it, they’ll send you a new blade guard and table top, free.
-- Tim-- http://www.tmuli.com
dbray45
#2 posted 612 days ago
Thanks, it not on the list
827 posts in 663 days
#3 posted 612 days ago
That saw is considered one of the best (by many) that Sears offered (Radial 100, isn’t it?) I had a slightly later model that wasn’t as well regarded, and it couldn’t be tuned…but a lot of folks have been able to get your model to be very accurate. Tune it carefully (follow the manual) and it should serve you very well. I think it is on the recall list (I had one, and sent the motor in…but it was completely shot), but not for a replacement table/guard. For the older ones, Emerson simply pays $100 for the return of the motor. Regardless, congrats…I’m sure you will find it’s an extremely useful tool. BTW, be sure to get a blade with a negative hook angle (Frued LU91 or similar). Makes those cuts so much nicer…just don’t try to rip cut with it.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
dbray45
#4 posted 612 days ago
Fred, thank you for the info. Yes, it is a Series 100. I was going to use one of my table saw blades. Once I get this cleaned up, the adjustments are seriously involved, I will get the blade.
dbray45
#5 posted 605 days ago
Fred – Got the blade, very smooth, clean, and no pull
Thanks again
View gfadvm's profile
gfadvm
6643 posts in 860 days
#6 posted 604 days ago
David – I have that identical saw (no one wanted it after dad died). A new switch, cleaning, and a fresh table top and it runs great. It looks like yours has the same metal cabinet as mine. I use mine primarily for breaking down long stock and leave it set at 90 degrees. I can’t get it to cut very accurate angles and it takes a lot of fiddling around to get the blade resquared so I just use it for straight cuts as it cuts wider stock than my miter saw. This next is very controversial: I push my saw rather than pulling it as most folks do. I didn’t know any better when I first got it running. I like pushing it and feel safer after trying both ways. Now duck cause the feces are fixin to hit the fan with subsequent comments!
Beginningwoodworker
13225 posts in 1843 days
#7 posted 604 days ago
Congrats thats a nice RAS!
-- CJIII Future cabinetmaker
View mountainaxe's profile
mountainaxe
61 posts in 675 days
#8 posted 603 days ago
If you want to use this saw for anything other than rough crosscuts, I highly recommend you find and use a copy of Jon Eakes’, Fine Tuning Your Radial Arm Saw. It contains the best method I’ve found to keep my Craftsman RAS (113.23100) in precision order—all the time. It’s been out of print for some years, but you can download it for $14.95 at http://joneakes.com/products. I would also note that the manual for any Craftsman RAS is horrible and even provides some incorrect information…I found it to be incredibly frustrating as you can’t set the saw up/adjusted properly using their instructions.
-- Jeff, "The things I make may be for others, but how I make them is for me."
dbray45
#9 posted 603 days ago
It took me a whole evening but the end result is that at 90 and 45 degrees in both directions, it cuts true. The manual was helpful in that the arm was locked because someone tried taking it apart and didn’t put it back together correctly. The component breakdowns were very helpful.
I will look into the book.
View rance's profile
rance
3856 posts in 1330 days
#10 posted 603 days ago
I push too gf… It is safer. :)
gfadvm
#11 posted 603 days ago
Rance – Where were you a few months ago when I got crucified for posting my ‘backward’ approach to using the RAS? I was pretty much the ‘Lone Ranger’ when it came to pushing (but I never considered changing!!!). Good for us huh?
dbray45
#12 posted 603 days ago
Just as a note, I am buying a manual mitre saw to augment the RAS. I have no desire to have my fingers and toes too close to this spinning blade.
The tip on the negative pitched blade is very nice and reduced the tendency to grap by at least 50%.
rance
#13 posted 603 days ago
I generally don’t care what folk think about me. :P I’ll back you up with “The safe way to use a RAS”. You may get tearout on the top, but pushing is infinitely safer.
View ChicoWoodnut's profile
ChicoWoodnut
904 posts in 1985 days
#14 posted 603 days ago
I’m not wanting to start a rant but doesn’t pushing risk making the work want to lift off the table throwing everything backward in an instant?? I’ve owned a RAS for many years. I’m doin it the way they designed it (pull)
I used to rip with my RAS (that is scary stupid) before I got a table saw. Now I just use it to cross cut dados make tenons and cross cut work that is too long for the TS. Very specific uses and I never change it from 90.
A useful tool
rance
#15 posted 603 days ago
You are right, that is the risk of pushing. The key is to hold the board down so it don’t do that. I’m not trying to be smart-alek, really. I prefer the push rather than the risk of pulling because with pulling, you risk the blade wanting to climb. If/when it does climb, it is coming right at you like a Lion…. with BIG TEETH. Pushing is not for everyone though.
It seems that the mfrs. got the Sliding miter saw and the RAS push vs pull backwards. I don’t mind pulling the sliding miter because you can raise the blade while pulling if it tries to climb. The RAS will just dig in because it has no place to go. Hope this explains my position. Knowing your tools is key here. Me too on not trying to start anything.
