What is the use of a skew bench chisel?
Forum topic by TopamaxSurvivor posted 09-19-2011 06:26 AM 2533 views 0 times favorited 10 replies Add to Favorites Watch
TopamaxSurvivor
18312 posts in 3730 days
09-19-2011 06:26 AM
Topic tags/keywords: skew bench chisel purpose
Reading a review of Narex skew bench chisel made me wonder where a skew chisel excells over a straight chisel?
10 replies so far
View Brett's profile
Brett
950 posts in 2813 days
#1 posted 09-19-2011 07:01 AM
It is good for cleaning out material in tight corners or spaces, such as dovetails, or any corner/inside angle where a straight chisel won’t reach. There may be more but that is what I would use it for.
Here is a good example in this picture
-- Hand Crafted by Brett Peterson John 3:16 http://www.TheCrookedNail.blogspot.com
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3169 days
#2 posted 09-19-2011 08:01 AM
some even have long parring scewcheisels as well as cranked parrings cheisel
that can clean those points that is so difficult to reach
Dennis
View ChrisCrafts's profile
ChrisCrafts
107 posts in 2639 days
#3 posted 09-19-2011 08:12 AM
It’s for when you Skew up your project. Ba da ba!
-- Chris, Washington The State! http://www.chris-crafts.com
TopamaxSurvivor
#4 posted 09-19-2011 08:56 AM
I’d better get one of each size; small, medium and large. That should cover all the projects I skew up ;-))
View mafe's profile
mafe
11739 posts in 3143 days
#5 posted 09-19-2011 11:49 AM
Hi Topa,
The skewed blade makes you able to make a sliding movement through the cut.
When your cut normally you hit the surface with the full width of the chisel at once and push throught the fibers. With the skewed you hit the cut with the skewed angle and then slice your way through.
This is especially super effective on endgrain. When you use it bevel down you also increase the angle of attac compared to how you hold it.
They can also be used for cleaning out dovetails and other, but for that purpose I would buy a fishtail chisel instead.
I made a set my self of old chisels you can see here:
http://lumberjocks.com/projects/45520
The beauty of the skews is that they can be used in applications (apart from d/t sockets) where a normal straight ground chisel may cause significant tear out. F’rinstance, I use them a lot to shape the ends of exposed tenons before smoothing and rounding…the slicing cut doesn’t tear the grain whereas a cut with a standard LN chisel might – Rob
http://investigationsblog.wordpress.com/2010/06/07/plane-skew-angles/
Ok that should be enough.
Good luck,
Mads
Dick, & Barb Cain
8693 posts in 4354 days
#6 posted 09-19-2011 01:29 PM
I not sure which came first, the Guillotine, or the skew chisel.
The French must have been pretty smart to have used this in their design.
View jim C's profile
jim C
1472 posts in 3153 days
#7 posted 09-19-2011 01:41 PM
To skew or not to skew…......that is the question!
The French skew up everything they touch.
TopamaxSurvivor
#8 posted 09-19-2011 06:32 PM
Thanks Mads. I can’t believe I missed that post of yours. I guess I will discover the advantages of skews as I get into higher quality WW.
View Bill White's profile
Bill White
4982 posts in 4015 days
#9 posted 09-19-2011 07:10 PM
Scews work the same as using a smoothing plane at an angle. Easier to pare the wood.
Bill
-- bill@magraphics.us
View mafe's profile
mafe
#10 posted 09-19-2011 08:08 PM
I still just fool arround, but discover a lot as I do.
But I have a French grirlfriend so I might be all skewed…
Big smile,
Mads
