I have just recently purchased a Laguna Cflux1. During assembly I noticed that it runs on 110v
#. So frustrated.
Which brings me to my question. I was able to hook up the DC to a 20amp breaker and it worked fine. So I am wondering if anyone else that has a Cflux1 can chime in and tell me what they have done for a power supply. Whether they have used a 110v 20amp or a 110v 30 amp.
Thanks for your Time,
Darren
Code:
18.8amps and that they recommend a 110v 30 amp breaker. My problem is that I dont have a 30amp outlet. I figured I would just buy the conversion kit to switch it over to 220v and that would solve my problem. But it didnt. The switch assembly they sent me just gave me a continuous beeping when i plugged it in. So I called them and they sent me a second assembly. And It did the same thing. I checked my outlet and it is putting out 240v. I dont have any other 220v tools to plug in to double check the outlet. So i called Laguna again, and they gave me a third switch that they tested in their shop. And it worked! for 2 days. Then I walked into my shop to find it beeping again.
Code:
Darren
