Cheap and easy Dust Collector Piping
Forum topic by Mike posted 09-18-2011 06:54 AM 5277 views 0 times favorited 7 replies Add to Favorites Watch
View Mike's profile
Mike
406 posts in 2593 days
09-18-2011 06:54 AM
Topic tags/keywords: resource trick tip dc dust collector pipe tube easy simple
So I was looking a while ago at the 4” pipe for dust collectors and I really didn’t want to spend an arm and a leg since I am renting the house my shop is in. I was looking for something that I could get that would do the job, but also not be a problem to replace if I moved. After looking around at Grizzly, HF, and tons of websites, I finally figured I should take a coupling from my system over and see what I could come up with.
I found a guy who worked in the plumbing section and asked him what he might have for a solution. After taking a look at the PVC pipe and decided that the cost was way to high, we went over to the AC section were the same conclusion was made. Being that it was the middle of last winter and there was snow falling at the time I figured that there might still be some 4” drainage PVC piping out in the Garden section left over from the warmer weather. I asked the store rep if he would help me look. Grabbing every warm piece of clothing that he could find (it was well towards 0 F) we headed out.
I took the coupling that I had brought with me and stuck it in the end of the tub. It fit! The only downside was that there was a 1/4” space in some areas of the black pipe around the couple. I squeezed the piping around the coupling and found that it would flex easily. I decided that worst case, if it didn’t work out, I could find another use for it. I got a spool about 30 ft long for under $25 – $30.
After an interesting time getting it into my Hyundai Elantra, I got it home and into the shop. I cut a section off for my jointer and took four pan head screws and attached it to the jointer and dust collector. Each screw was fastened at a 90 degree angle to each other. I turned on the collector, turned on the jointer, then started jointing a scrap board. Turning both the DC and jointer off, I took the out put chute off the jointer to inspect inside the black tubing. Success! There were no chips in either the jointer output shoot nor the black pipe! I reassembled everything and for the first time ever, I finally used Duct Tape for its designed purpose.
Well I have been using this system for over 6 months now without any problems or jams as a result of the pipe. The valleys on the piping don’t even collect any chips and everything gets to the DC. I have some tubing that runs some ten to fifteen feet with out any problems.
I hope this helps!
-- look Ma! I still got all eleven of my fingers! - http://www.lepelstatcrafts.etsy.com - https://www.youtube.com/channel/UCppWfrYGXCr5lm9uW-Fpqqw
7 replies so far
View cloakie1's profile
cloakie1
204 posts in 2461 days
#1 posted 09-18-2011 10:48 AM
thanks for tip….might have to look at that….i have yet to install some sort of system but i am at a point where i badly need too
-- just get stuck in and have a go!!!
View Grandpa's profile
Grandpa
3259 posts in 2581 days
#2 posted 09-18-2011 10:03 PM
yes, Could you show us more about the black pipe. Since it is flex does it collapse or is it corrugated or what. Can you show us more about the subject.
View Howie's profile
Howie
2656 posts in 2829 days
#3 posted 09-18-2011 11:00 PM
Thanks for the tip.
For the life of me I don’t see how they can justify the price for d/c stuff. Captive audience I suppose.
-- Life is good.
Grandpa
#4 posted 09-18-2011 11:03 PM
Market isn’t flooded yet. Once they do flood the market most of them will drop out and the rest will have to lower their prices. All supply and demand.
View David Grimes's profile
David Grimes
2078 posts in 2546 days
#5 posted 09-18-2011 11:08 PM
I believe that the “objection” to using this type of pipe is the loss of efficiency with the corrugated sides, not that it holds the material being collected. In your application, your 10-15 foot runs are relatively short so you are able to stand the loss.
However, if someone were to use this type of material in a system where 50 – 100 feet is possible / typical, then the loss of efficiency would be a problem… even a show stopper.
It is great when something works for your needs so well and at such a small price, but it is not a substitute for smooth wall ductwork for larger and/or more demanding systems.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View rance's profile
rance
4256 posts in 3066 days
#6 posted 09-18-2011 11:47 PM
>“without any problems or jams as a result of the pipe. “
Have you had other obstructions as a result of something else?
David Grimes
#7 posted 09-18-2011 11:51 PM
The chihuahua will NOT stick to the table with peanut butter, but he may make it safely to the separator baffle.
