Quick finish over stain?
Forum topic by chad515 posted 12-16-2018 01:38 PM 319 views 0 times favorited 6 replies Add to Favorites Watch
View chad515's profile
chad515
7 posts in 273 days
12-16-2018 01:38 PM
Topic tags/keywords: question
I have some Oak and Ash panels that I glued up. I stained them with Minwax oil-based stain, and then my wife painted some words/designs on them using acrylic paint. These will hang on the wall, so I’m not too concerned about protecting them (they won’t be touched or spilled on, etc.).
I now wonder if I need to put a finish on them. I was not planning to, but I wonder if that’s a bad idea. So my questions are:
1. Do I need to put a finish over the top? Or does the stain already provide a bit of protection against discoloring?
2. If I need a finish, what’s a quick finish that I could put on that wouldn’t change the appearance much?
Thanks for any help!
View WoodshopTherapy's profile
WoodshopTherapy
27 posts in 344 days
#1 posted 12-16-2018 01:58 PM
Unless you’re going for the rustic look, I would put a finish over the top so it’s easier to dust and keep clean.
I recommend a spray finish using an aerosol can. You can choose either a polyurethane or a lacquer. The lacquer dries faster, but it’s more toxic, so you need a well ventilated area and a respirator with carbon filters.
I hope that helps. Post a photo and show us your work!
-- Scott Bennett - sharing woodworking knowledge at Home Improvement Woodworking
View Redoak49's profile
Redoak49
3744 posts in 2229 days
#2 posted 12-16-2018 01:59 PM
You could try a spray can shellac and use a light coat. A couple of very light coats should minimize the acrylic from any runs.
View Rich's profile
Rich
4012 posts in 829 days
#3 posted 12-16-2018 03:19 PM
I recommend a spray finish using an aerosol can. You can choose either a polyurethane or a lacquer. The lacquer dries faster, but it s more toxic, so you need a well ventilated area and a respirator with carbon filters.
- WoodshopTherapy
Correct to use an aerosol to reduce possible smearing. Totally wrong that you only need ventilation and a respirator for lacquer. You should use a respirator for any finish, spray, brush or wipe, that contains VOCs, and do it in a ventilated area.
chad515
7 posts in 273 days
#4 posted 12-16-2018 08:44 PM
Thanks so much. So, I guess aerosol it is. Is there such a thing as matte finish in any of these? I see satin spray lacquer. I guess that could work.
View Rich's profile
Rich
#5 posted 12-16-2018 09:21 PM
- chad515
Mohawk offers matte and flat lacquer in aerosol cans.
View dannmarks's profile
dannmarks
775 posts in 821 days
#6 posted 12-16-2018 10:47 PM
Lacquer dries fast… and that keeps dust from being in the finish. I usually spray out side my self. And if I do not trust the weather or it is windy I spray in a shed with whole front open (Big doors) so that no leaves or less bugs get on it and of course rain. Rule of thumb is 50 degrees is needed for it to dry properly.
