Squaring a case
« back to Joinery forum
Forum topic by scribble posted 12-15-2018 08:28 PM 521 views 0 times favorited 11 replies Add to Favorites Watch
View scribble's profile
scribble
204 posts in 2438 days
12-15-2018 08:28 PM
Topic tags/keywords: question tablesaw joining traditional
I decided to tackle a new router cabinet and make a huge flaw when assembling. I didn’t check the case square before all the glue dried. It didn’t dawn on me till I was thinking of putting on my back. I’m trying to figure how to square it one lace the glue has dried short of making a new case. If I was a just slightly off I’d leave but I’m 1/2” out side to side. Please help me save what hair I still have.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
11 replies so far
View Jack Lewis's profile
Jack Lewis
369 posts in 1316 days
#1 posted 12-15-2018 08:46 PM
Show construction! Mitered sides, box joint? Room enough to split the joints on TS and correct?
-- "PLUMBER'S BUTT! Get over it, everybody has one"
scribble
#2 posted 12-15-2018 08:48 PM
Sorry it was dado construction. All the way.
View waho6o9's profile
waho6o9
8539 posts in 2815 days
#3 posted 12-15-2018 09:02 PM
Check you diagonals then gently bounce it off the concrete on the long diagonal measurement
add the back to square it up.
Best of luck.
View socrbent's profile
socrbent
740 posts in 2507 days
#4 posted 12-15-2018 09:13 PM
If you could make the case square by widening or narrowing base, then I suggest cutting the base parallel to the side, front to back in middle making the base wider or narrower as needed, and then install a piece of plywood or mdf cut to fit inside on top of base or below the base as a reinforcement over the entire base. Glue and screw the patch in place.
-- socrbent Ohio
View WoodenDreams's profile
WoodenDreams
377 posts in 149 days
#5 posted 12-15-2018 09:48 PM
You can leave the cabinet as is, and make adjustment to the back panel, and maybe add supports to help with lateral thrust, if this doesn’t effect the tabletop. If you have slide drawers. you’ll have to adjust for that.
View steve104c's profile
steve104c
51 posts in 1476 days
#6 posted 12-15-2018 10:40 PM
If you haven’t put a back on, lay on face and rabbit around and insert a squared piece of plywood. Use a long clamp diagonal across the corners. Screw down clamp until plywood fits inside rabbit. This should be close to square. This can work on a pretty out of square piece without hurting it. Steve.
scribble
#7 posted 12-15-2018 10:49 PM
I want to thank everyone for there suggestions. I am lucky (well not really the brightest time to build) that Titebond doesn’t like Wisconsin winters and it really never set up. I was able to release the glue and reset the entire case. I added screws to all of my dado intersections and racked the case into square. I wish I had a heated shop and was able to get this built months ago but some recent vacation from the 3 jobs became available and I snapped at the opportunity to get this project started. I probably won’t get it completely finished till next spring but at least I can start using my router again for some little projects that need touch up.
View Kazooman's profile
Kazooman
1268 posts in 2190 days
#8 posted 12-15-2018 11:06 PM
Good to hear that you were able to get the joints loosened and then square the case properly. I was going to chime in that a router table was one project where you really didn’t want to mess around with brute force to set things right. It seems like such a simple project that we can easily just “make do”. However, the quality of the build of your router table will be passed through to all of your future projects. It’s just like making a jig for your table saw. It is the one time to really focus and get everything dead nuts on.
View AAL's profile
AAL
80 posts in 1664 days
#9 posted 12-15-2018 11:12 PM
Nice to hear someone getting a lucky break!
-- "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#10 posted 12-15-2018 11:36 PM
Ask Santa for a shop heater.
-- Bondo Gaposis
scribble
#11 posted 12-16-2018 02:31 PM
- bondogaposis
So do I, need a new garage/shop but house comes before my toys.
