Lessons learned
« back to Coffee Lounge forum
Forum topic by MrRon posted 12-15-2018 06:09 PM 401 views 0 times favorited 8 replies Add to Favorites Watch
View MrRon's profile
MrRon
5264 posts in 3481 days
12-15-2018 06:09 PM
Having worked in the shipbuilding industry all my life, a topic that always came up after the completion of a ship was “lessons learned”. I’m sure this has come up in the military and other industries also. The purpose of lessons learned is to keep from making the same mistake on the next project. Lessons learned is a particularly valuable ingredient in woodworking. To start this off, I will present one of my “lessons learned” experiences.
If I was building a wood project, I would first make a drawing, then select the wood and lay out the cuts to be made. I would then go to my saw and make the necessary cuts, only to realize the parts don’t go together as they were planned, because the depth of cut was too shallow or too much or I would end up with a piece that was too short. Remember you can always make another cut, but you can’t do anything about a too short piece. That is where I now take trial cuts on scrap to insure it is correct before cutting into the good wood. I also cut to as precise a dimension as I can. I may make multiple trial cuts until I’m satisfied that it is correct. This takes time, but you are rewarded with a finished piece that goes together flawlessly.
I post this in Coffee Lounge, because lessons learned applies to all areas of construction. What is your “lessons learned”?
8 replies so far
View therealSteveN's profile
therealSteveN
1903 posts in 812 days
#1 posted 12-15-2018 06:57 PM
Probably same as a lot of others.
Measure 3 times, cut once, then start cussing…...
Seriously, because of doing that I try to “measure” as little as possible, and use parts to make other parts depending on known lengths, and also using story sticks. Cause sure as the grass grows in the spring, you WILL make measuring errors, and then you will start cussing. DAMHIKT.
-- Think safe, be safe
View ralbuck's profile
ralbuck
5534 posts in 2504 days
#2 posted 12-15-2018 07:25 PM
If it is something that needs to be accurate, beyond reasonable’ I deliberately cut a tiny bit long and then sand carefully to the exact size. Much easier to sand it off instead of trying to add it back on. My welder does NOT work well with wood!
-- Wood rescue is good for the environment and me! just rjR
View 000's profile
000
2859 posts in 1137 days
#3 posted 12-15-2018 07:33 PM
I have lots of “Lessons Learned”
problem is that next time I do it it may be 6 or 8 months later and I forget the lessons learned,
that is until I make the same damn mistake again and go…
Oh yeah….. :>/
My biggest lesson learned that I could pass on would be not to rush a finish.
Things always go south in a hurry. Stuff just has to dry, period.
View OSU55's profile
OSU55
2026 posts in 2227 days
#4 posted 12-15-2018 10:09 PM
Too many to list, just thinking about it I’m not sure where to start…..
The finish is 1/2 the project (for furniture etc), so spend the same amount of time developing knowledge and skills as spent on designing/building, the finish is part of the design process.
Learn how to research/investigate topics. Dont stop at the 1st or 2nd source of info – they are many ways of doing things in ww. Easy to find what appears to be a good method, but has drawbacks the presenter doesnt cover because they dont realize it or intentionally “cover it up”. Think it through – does it really make sense?
Stanley Bailey design hand planes work great with oem irons and chipbreakers – no need for thick, expensive aftermarket parts. Learn proper tuning and sharpening.
Oil based poly sucks to spray – overspray turns everything into sandpaper
Water based finishes have no chatoyance, but oil or shellac under them can help a lot
120V table saws have enough power for hobbyists – a good blade and slower feed rate works every time. Time is not $ to you.
MrRon
#5 posted 12-16-2018 06:37 PM
Here is another “lessons learned” example: When fastening two pieces of wood together with screws or nails, you will usually end up with a misaligned result, like on a picture frame. To prevent this, use clamps to hold the pieces together in their proper position before driving a screw or nail. Once that screw or nail is driven, it is impossible to correct any misalignment. Take the time necessary to do it right.
View Desert_Woodworker's profile
Desert_Woodworker
1673 posts in 1452 days
#6 posted 12-17-2018 03:27 AM
Many, but that is life… Most importantly learn from them.
For example $$$ of damaged bits- because it was ME who told the CNC what to do.
-- Desert_Woodworker
View TheFridge's profile
TheFridge
10816 posts in 1724 days
#7 posted 12-17-2018 04:22 AM
DW is so mean to his CNC. That’s child abuse in some circles.
Desert_Woodworker
#8 posted 12-17-2018 05:20 AM
So quick to judge, young Alder Prince-
Look at the photos- there is no ALDER abuse in the test
When it comes to the final process- I only cut ALDER on my machine…
