| Forum topic by Chiefk | posted 85 days ago | 108 views | 0 times favorited | 4 replies | ![]() |
85 days ago |
I am buillding an entertainment center with several doors. I would like to bookmatch the panels in the doors. As I understand it I want the veneer to be between 1/16 to 1/8 inch thick. I also need to veneer both sides of the substrate. What do I use as a substrate that when the veneer is applied to both sides will then fit into the grooves in the rail and stiles? Also can I just resaw the wood to form the bookmatch panels so that after planing and sanding it will be 1/4” thick? My concern would be about the stability of 1/4” panel. Thanks, pkennedy -- P Kennedy Crossville, TN |
