| Forum topic by MsDebbieP | posted 613 days ago | 1774 views | 1 time favorited | 30 replies | ![]() |
613 days ago |
Topic tags/keywords: rust equipment tips tricks What are your tips/strategies to prevent and/or remove rust from tools & equipment? (also add links to helpful blogs etc that are related to the topic) Gateway to all Tips & Tricks Topics -- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
30 replies so far
#1 posted 613 days ago |
I cover all my iron tools and tops with Crisco. It keeps them rust free, nice and greasy and smells great on those hot summer days… Butter is even better but that would just be crazy…
-- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com |
#2 posted 613 days ago |
I used to use “Simonize” Wax on all of the metal surfaces of my equipment. I can no longer find it. I have tried a lot of other waxes (most have silicone in them) but they just won’t hold up well. The only other wax I have found that is close is “Mothers Wax”. -- Measure twice, cut once, and hope for the best. |
#3 posted 613 days ago |
I use Boe-Shield, and Johnsons paste wax (no silicon) on all my table-tops at least once a month, or whenever needed. (when wood doesn’t seem to be gliding). -- Roger from KY. Work/Play/Travel Safe. Kentuk55@bellsouth.net |
#4 posted 613 days ago |
I am an advocate of paste wax, though it needs frequent reapplication. For hand tools, I am trying jojoba oil, but I haven’t had time to form a solid opinion of it yet. A jojoba soaked microfiber cloth (AKA “Super woobie”) is currently hanging from a hook beside my tool storage area, and everything gets a wipe down before it goes up. So far, I certainly like this system, and the jojoba oil is a lot nicer to deal with than WD-40. -- David from Indiana -- |
#5 posted 613 days ago |
I used BoeShield T-9 on my TS, BS, and Jointer for awhile and was NOT that pleased with it. I have applied it thick and thin, also did the heavy coat/let dry/buff routines. My impression was that T-9 is an expensive product for rust prevention on cast iron surfaces that are continually used. I have dropped sweat on a freshly T-9’d surface and within less than 5min had a rust ring. That being said, I am now using Johnson’s Paste Wax on all my cast iron. I had originally bought this for use on my relatively recent workbench project but now use it on nearly everything. It is inexpensive, applies easily, leaves a nice sheen, and appears to last longer than the T-9. JPW may be the biggest bargain/bang-for-the-buck out there, IMO. -- HorizontalMike -- "Woodpeckers understand..." |
#6 posted 613 days ago |
Removal – Evapo-Rust…moderately inexpensive, reusable, gets in those hard to reach places, removes rust by soaking with minimal scrubbing, and it’s non-toxic from the can. Prevention – Johnson’s Paste Wax – no silicone, dirt cheap, it can be found almost everywhere, and it’s easy to apply. -- A man who carries a cat by the tail learns something he can learn in no other way. - Mark Twain |
#7 posted 613 days ago |
Beeswax based wax in my grease box, and sometimes a little acid free oil on a cloth. -- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking. |
#8 posted 613 days ago |
I use Johnsons Paste Wax on cast iron surfaces. When removing rust spots I wet sand using WD40 as the lube to prevent rust on the bare metal. I use Naval Jelly, but it stains the iron and you will have to wet sand to remove it. I’m about to try electrolysis for rust removal in a few days. In the middle of modding a PC power supply to do it. For hand tools I hear camellia oil or WD40 is good. Popular Woodworking recommends WD40 and Fine Woodworking likes camellia. WD40 is cheaper so I use that. Of course I live in dry northern Calif so rust is not as big of an issue. |
#9 posted 613 days ago |
One note on Evapo-Rust—it does discolor the metal slightly and seems to leave a matte finish in my experience. Unless the whole piece is coated in rust, I try and spot-treat rust with sand-paper (wet/dry) or scotchbrite with WD-40. I save the Evapo-rust for really nasty pieces, and it does a great job with those! -- David from Indiana -- |
#10 posted 613 days ago |
citric Acid and a fine brasswirebrush to remove rust with take care |
#11 posted 612 days ago |
There is always the diluted vinegar treatment. Cheap and very effective. Just leave it a few days and no more rust. -- Grumpy - "Always look on the bright side of life"- Monty Python |
#12 posted 611 days ago |
Paste wax (Johnson’s) to protect cast iron and sandpaper to remove rust. A new looking cast iron surface is pretty but too much trouble. I much prefer the “patina” of my 39 year old Craftsman bench saw. It looks as if it’s done something in its’ life. Camelia oil works for hand tools, but my hands don’t have the grip they used to and it makes it hard for me to hold stuff. Steve -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#13 posted 611 days ago |
Citric acid and a wire brush For prevention: a Dehumidifier maybe two. -- When the moderator chooses sides, his site sucks. |
#14 posted 610 days ago |
Control shop environment/air quality and rust isn’t even in the equation….ust sayin,BW |
#15 posted 609 days ago |
Sarit, please start a blog on the electrolysis…very interested in this. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
