How do you mask your miter keys?
Forum topic by Cato posted 09-17-2011 01:18 PM 2014 views 0 times favorited 11 replies Add to Favorites Watch
View Cato's profile
Cato
701 posts in 3307 days
09-17-2011 01:18 PM
I have been building a few boxes for gifts with different joinery on several of them.
When using mitered joints and installing a couple of miter keys for strength how do you mask them off when finishing so that you have a contrast between the keys and the box?
11 replies so far
View Pick's profile
Pick
30 posts in 3027 days
#1 posted 09-17-2011 02:15 PM
Just make them out of a contrasting wood, and then use a clear finish.
27250 posts in 3816 days
#2 posted 09-17-2011 02:26 PM
Cato, +1 on Pick’s comment. I will usually use maple to contrast with walnut or cherry, for example.
View Cato's profile
Cato
#3 posted 09-17-2011 02:30 PM
Pick- with the finishes I am using on curly maple for instance I am dyeing the maple brown and then finishing with a topcoat of amber shellac and I was trying to figure an easy way to keep the dye and amber shellac from coloring the miter keys.
Since the miter keys are the thickness of a saw kerf it seems like it would be hard to accurately tape them off, so I was wondering how others did it.
View tom427cid's profile
tom427cid
294 posts in 2465 days
#4 posted 09-17-2011 04:41 PM
Hi,
When I am trying to highlight something-before staining I will (very carefully) paint the part with thinned white shelaq. two light coats seems to provide a good barrier so the stain won’t penetrate the part that I want to contrast.
Hope this helps.
tom
-- "certified sawdust maker"
View Gene Howe's profile
Gene Howe
10477 posts in 3423 days
#5 posted 09-17-2011 04:47 PM
I cut everything first, insert the keys and bring them level. Then, remove the keys and stain the box, re insert the keys and glue.
View ShaneA's profile (online now)
ShaneA
6928 posts in 2593 days
#6 posted 09-17-2011 05:08 PM
The keys should essentialy be end grain, so they will absorb more stain than the face grain on the sides of the boxes. So there should be a noticeable color difference even without masking. However, as stated above, I usually use a contrasting wood with just an oil finish.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3280 days
#7 posted 09-17-2011 06:29 PM
Unfortunately, taping for stain usually doesn’t work. The stain generally runs under the tape, and you end up with a mess. That is simply the nature of stain. If it didn’t soak in, it wouldn’t be stain.
As others mentioned, because the keys are end-grain, they will take the stain darker.
It would be difficult for the keys to be lighter though.
-- http://shepherdtoolandsupply.com/
Kent Shepherd
#8 posted 09-17-2011 06:36 PM
I just thought. (Wow, that’s a first!) If you want a lighter key, tape carefully around them. With a small artist brush, seal the keys with the finish you are using. Then tape the keys and stain, being careful not to use excessive stain close to the tabe. The sealer should help keep the stain from soaking in.
I would try this before possibly ruining a nice box.
Good luck
View Cato's profile
Cato
#9 posted 09-18-2011 01:58 PM
thank you all for the responses on this.
Kent I was kind of thinking along the same lines as you have suggested, or maybe making a set of dummy keys to put in while I dye the box carcass and shellac it, then remove those and tape around the key slots and glue in the lighter keys.
View speakerscott's profile
speakerscott
47 posts in 3833 days
#10 posted 09-18-2011 03:01 PM
Cato,
I’ve been working on a table design where I’d like to highlight the inlay. The method I see for Federal period pieces is to get a very fine tipped brush and put clear finish/light finish on the inlay. I’ve yet to actually attempt this…so we’ll see how it goes.
Scott
-- Scott, Austin-Texas...
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3707 days
#11 posted 09-18-2011 03:07 PM
Could you cut your mitre slots after you’d stained the box? Then slide in your keys and finish them as required.
