Question on 3 piece plane iron
« back to Hand Tools forum
Forum topic by Don W posted 09-17-2011 02:58 AM 1886 views 0 times favorited 27 replies Add to Favorites Watch
View Don W's profile
Don W
18554 posts in 2437 days
09-17-2011 02:58 AM
I have this old wood plane with a different kind of iron. Its 3 piece. Its a cap iron and the other 2 pieces have a angle like they are sharpened. They are two rusty to really tell if they were sharpen together or in some other fashion.
Can anybody tell me anything about it?
27 replies so far
View WayneC's profile
WayneC
13751 posts in 3966 days
#1 posted 09-17-2011 03:03 AM
I’ve not seen one like it…
Don W
#2 posted 09-17-2011 03:05 AM
The top small nut is grooved so it rides in the slot. At first I thought it might be a way to adjust it, but that wouldn’t work. I’m stumped.
WayneC
#3 posted 09-17-2011 03:06 AM
Record had a stay set blade. Might be something like that.
http://www.toolsforworkingwood.com/indextool.mvc?prodid=EE-SS-635.XX
View BTKS's profile
BTKS
1986 posts in 3333 days
#4 posted 09-17-2011 03:55 AM
I’m taking a wild guess. I’ll bet the thick one is to stiffen a thin cutting blade. Tool steel costs much more than cheap iron. The cap plate holds the thin blade to the stiffener and you have mass with very little high grade steel. Like I said, a wild guess.
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View RGtools's profile
RGtools
3372 posts in 2524 days
#5 posted 09-17-2011 04:29 AM
BTKS beat me to it. That would have been my guess as well.
-- Make furniture that lasts as long as the tree - Ryan
View David Kirtley's profile
David Kirtley
1286 posts in 2867 days
#6 posted 09-17-2011 04:32 AM
I would suspect that they made the extra iron to be able to fit the plane that had been made for a meatier iron.
RGtools
#7 posted 09-17-2011 04:34 AM
The other option would be that this was an attempt at keeping the bed for the iron stable to prevent chatter caused by seasonal movement in the wood…it did not work out well, which is why you don’t see this often.
View mafe's profile
mafe
11629 posts in 2958 days
#8 posted 09-17-2011 04:42 PM
Don I think this is just some one who had two irons and stored them in the plane like that.
Perhaps one for rough and one for smoothing.
I feel quite confident that it is not a doubble cutting iron, think about the shaves, they will automatically get stucked.
Best thoughts,
Mads
Don W
#9 posted 09-17-2011 05:13 PM
I don’t think so Mads. The middle one is way to thin to stand on its own and the cap iron only attaches to the outside “iron”. So if the outside (thicker) blade wasn’t there, there would be no way to attach the cap iron. I agree about the shavings getting stuck, but I think it was made to work as a set somehow for some reason.
View mafe's profile
mafe
#10 posted 09-17-2011 06:08 PM
The more I look the less sence it makes…
I think you are right it is a set – but?
WayneC
#11 posted 09-17-2011 06:10 PM
I would like to see some photos once the rust has been removed.
View mafe's profile
mafe
#12 posted 09-17-2011 06:13 PM
I think I figured it out!
The thin iron is acually the only one cutting.
The thick is fixed behind and set just where the thin one ends – and act only for stability.
The chipbreaker is a chipbreaker.
But why?
Because you can sharpen the thin blade in a few stokes and it is cheap to buy new.
Like a kind of early disposable blades.
I know there were many discussions abot the time for sharpeneing on the thick blades in the old day.
It’s acually really interesting and really unique.
Big smile buddy,
Mads
View mafe's profile
mafe
#13 posted 09-17-2011 06:14 PM
And I see that it is waht BTKS writes… Goodmorning Mads!
Don W
#14 posted 09-17-2011 06:20 PM
I’ll throw it in the evapo rust later.
View jusfine's profile
jusfine
2422 posts in 2795 days
#15 posted 09-17-2011 07:06 PM
Really interesting Don, I have not seen one like that anywhere!
Curious to see how it will perform.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
