Will it be safe? Advice appreciated
Forum topic by barneyrubble posted 12-13-2018 04:17 PM 468 views 0 times favorited 11 replies Add to Favorites Watch
View barneyrubble's profile
barneyrubble
2 posts in 37 days
12-13-2018 04:17 PM
Topic tags/keywords: disc sander tablesaw question safety
Hi. I am a hobby woodworker and have a no-name brand cheap table saw that is not used that I would like to turn into a badly needed disc sander. Problem is that it has a short arbor that won’t accept anything much thicker than a standard saw blade. Every home built sander of this type I have come across on the net uses a wooden disc with sandpaper glued on but I don”t think that is an option here as the wood would have to be be way too thin. My question is, has anybody any experience or knowledge of using an old saw blade with sandpaper glued to it to achieve the same end? I keep thinking about it but am just not sure if it would be a safe thing to do. Any suggestions or comments would be most useful in helping me make a decision. Many thanks.
11 replies so far
View Lazyman's profile
Lazyman
2707 posts in 1625 days
#1 posted 12-13-2018 04:29 PM
Not safe unless you can cut the teeth off of it so it is round. You can buy a flat disc specifically designed for that purpose here.
Note that the table saw is probably going to run much faster than dedicated disc sanders typically do so it will be more likely to burn.
View jutsFL's profile
jutsFL
160 posts in 79 days
#2 posted 12-13-2018 04:45 PM
Ya, that motor is going to way too high in the RPM range for what you’ll want. May want to look at a speed control option for it to slow ut down.
-- I've quickly learned that being a woodworker isn't about making flawless work, rather it's fixing all the mistakes you made so that it appears flawless to others! Jay - FL
View LittleShaver's profile
LittleShaver
455 posts in 857 days
#3 posted 12-13-2018 04:50 PM
I haven’t seen one in a while, but they do sell a flat disk for a table saw that you can attach sandpaper to. Using and old blade seems to me to be just asking for a trip to the ER.
-- Sawdust Maker
View Andybb's profile
Andybb
1613 posts in 841 days
#4 posted 12-13-2018 05:06 PM
I’d resist the saw blade option. If you do decide to make a disc sander you are going to need to use a variable speed controller or pulley combo to slow that baby down. Literally hundreds of DIY disc sanders on youtube. In fact, so many that I can’t even find the one I made to link to.
Found it. But there are much easier ones to make.
-- Andy - Seattle USA
View BlasterStumps's profile
BlasterStumps
1071 posts in 677 days
#5 posted 12-13-2018 05:10 PM
With very little materials, a 1725 RPM motor, and a little time on your part you could make a disc sander. I found a motor this last summer and mounted a flange to the shaft then added a disc to it. The table I made on it doesn’t tilt but I have other tools that will take care of that. It is cheap, easy and even has dust collection. My cost for the 3/4 HP motor was $10. The rest was stuff I had. Several DIY videos on YouTube.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View pottz's profile
pottz
3826 posts in 1222 days
#6 posted 12-13-2018 07:58 PM
this is probably what your looking for,much safer than sticking sandpaper on a spinning blade-ouchhh!
View HokieKen's profile
HokieKen
7562 posts in 1376 days
#7 posted 12-13-2018 08:40 PM
I have one of those discs^ that I’ll send you if you want it. Just PM me your address. I got it a long time ago and used for aligning my arbor with the miter slot. Never actually put sandpaper on it. But, it’s only been used once and is just taking up space. It’s yours for the price of shipping. As others suggested, you might want to see about slowing the motor down though. If it’s a belt drive, just a pulley change might be all that’s needed.
-- Kenny, SW VA, Go Hokies!!!
barneyrubble
2 posts in 37 days
#8 posted 12-14-2018 02:01 AM
Thanks to all who commented here and you have confirmed my suspicions that it is not a good idea so I will find another way. I’d rather be safe than sorry. And many thanks HokieKen for the offer of the disc ( didn’t know about them before so learned something) but I shan’t be needing it now as I will try something else. I live in Thailand and the shipping plus the huge tax I would have to pay made it a bit of a non starter for me anyway but thanks all the same.
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#9 posted 12-14-2018 02:52 AM
Not a good idea, way too many RPMs for sanding.
-- Bondo Gaposis
View 000's profile
000
2859 posts in 1137 days
#10 posted 12-14-2018 02:57 AM
I understand the RPM’s are too high,
so how do they get away with making a disc specifically for your table saw?
I know the pros and cons, but I guess it works for some things. Takes a light touch.
View TheFridge's profile
TheFridge
10816 posts in 1724 days
#11 posted 12-14-2018 03:14 AM
Kinda like belt sanders.
In the hands of someone with experience, it’ll work great and cut down the time it takes to do an operation.
In the hands of a novice, it’ll have you building new parts or modifying your project before you know it.
