General E-Z Pro Mortise and Tenon Jig
Forum topic by pintodeluxe posted 09-15-2011 10:31 PM 5812 views 0 times favorited 4 replies Add to Favorites Watch
View pintodeluxe's profile
pintodeluxe
5706 posts in 2841 days
09-15-2011 10:31 PM
Topic tags/keywords: mortise and tenon mortise tenon router jig
Has anybody seen these? It is a mortise and tenon jig for use with your plunge router. It is described on generaltools.com and looks pretty good. It includes a spiral bit and guide bushings. Priced at $149 it should give Leigh a run for their money. Should be available in stores in late September 2011.
Now all we have to wait for is Festools patent to expire on the domino!
View Chipy's profile
Chipy
374 posts in 2621 days
#1 posted 09-15-2011 11:12 PM
Yes check out my post in forum…. Jigs and fixtures.I want one of thees BAD!
pintodeluxe
#2 posted 09-27-2011 05:48 PM
Rockler now has these jigs in stock!
View breaknrn's profile
breaknrn
39 posts in 4024 days
#3 posted 10-04-2011 04:31 PM
I have been to the general tools site several times over the past few weeks drooling over this. I think it’s a great idea, but see two drawbacks:
- I’m not convinced that this is the best way to cut tenons because it will be awkward to clamp long pieces to the fixture
-Their corporate videos show a flush and snug joint, but I don’t see any positive registration mechanisms so you make sure the mortise and tenons line up along the rail where you want it (like at the end of stiles), and also make this repeatable? I guess you can work around this by making the mortise slots wider than needed and then just slide the tenon back and forth until it is where you want it precisely to be (similar to how biscuit joiners work).
I’d like to try it out before I ultimately buy it. Any other thoughts?
-- breaknrn
pintodeluxe
#4 posted 10-04-2011 05:37 PM
Breaknrn,
I have some reservations about cutting tenons this way as well. In general I will always choose a cutting operation with the stock lying flat on a stable surface when possible (ie: cutting tenons with a dado blade on the T.S.). However, I have plans for the Rodel chair which calls for floating tenons and end-grain mortises. This would be just the tool for cutting end-grain mortises.
Regarding your concerns, the jig works off of centerlines. Just mark the center of the mortise and the center of the tenon. Align those marks to the centerline on the jig to create flush joints (just like biscuits).
I have two complaints with their jig concept:
1. Although the mortise slot looks simple enough to rout, the tenon guide requires you to maintain contact between the router bushing and the jig at all times. Otherwise you will mar the tenon. I much prefer the looks of the Leigh frame and mortise jig that makes the tenons automatic.
2. It is a real pitty that General didn’t include a way to cut angled tenons. These are useful joints for chair building. Angled mortises are easy enough with a hollow chisel mortiser, but angled tenons are a real pain without the proper jig.
