Hi Everyone,
So for context, this is the first thing I've ever made. New saw, new everything. Bought a 2×4x4' of S4S red oak from Menards and am attempting to make this frame. As you can see I managed to burn the wood pretty thoroughly (new Freud Fusion TK combo blade on Dewalt DWE7491RS saw). Could have been my feed rate (being my first-ever cuts I wasn't trying to break any speed records), or something else. I did spend 2 days setting up the saw before I ever turned it on. I used a Mitutoyo dial caliper that reads ten thousands of an inch, calibrated miter slot to be .0002" from front to back. Also used a Starrett double square to set the blade and Incra 1000HD miter gauge up. Without rambling on any more, I really, really tried to nail the setup so that hopefully things would line up nicely when assembled. And to be honest, the 4 mitered corners turned out pretty nice. Only issue was the 2×4 seemed to warp a bit when I ripped it to the 2×2 pieces. And since I don't have a planer or jointer I was a bit stuck dealing with it.
Anyway, first question is what would you guys recommend to get rid of these burns? I was going to pick up a card scraper today to see how that worked. Sanding knocked it down a bit, but seemed like it would be a long haul to get it all and might leave a wavy surface in the end.
Secondly, I really screwed up when trying to quickly trim my corner spline pieces to make for less chiseling (perhaps it was the 2 hours it took me to sharpen a single new chisel that had me a bit impatient!). I was using a miter saw for that and managed to cut into the main wood. Ugh! What's my best bet for a newb-skill-level recovery on this? Sanding? Planing (bearing in mind I don't have a nice plane, just a cheap home depot on about 4" long)? Running it back over the table saw? I also have a Bosch router and table that aren't even out of the box yet. But was trying to limit the number of tools I don't know how to use for this first project lol.
Definitely having fun with all this stuff but I'm trying to salvage this as a usable frame given all the time I have put in so far, and if I don't get some advice on how to wrap it up I'm afraid that might not happen
Thanks for reading!
Jeff
Thanks for reading!
Jeff
