Bent lamanation settling
Forum topic by EandS posted 09-15-2011 09:30 PM 1256 views 2 times favorited 6 replies Add to Favorites Watch
View EandS's profile
EandS
73 posts in 2517 days
09-15-2011 09:30 PM
I was experimenting with bent lamanations today for some modernistic tables. I noticed when I removed them from the form that they have lost shape from the form a considerable bit. Now this isnt to say that the pieces are ruined. They still are bent perfectly and seamlessly and will work GREAT with this table I am just wondering.
Is this typical for a lamanation to settle after its unclamped? Should I leave it clamped longer? Use a different type of glue?
Any advice would be accepted.
-- ~ eandscarpentryandwoodworking.com ~
View SASmith               's profile
SASmith
1850 posts in 3042 days
#1 posted 09-15-2011 11:30 PM
What glue did you use? Most people over-bend the lamination knowing it will spring back.
-- Scott Smith, Southern Illinois
EandS
#2 posted 09-15-2011 11:41 PM
I used white Gorilla glue. I covered the entire surface 100 percent of course.
Thats what I thought about it springing back, I just wanted to check with you guys and make sure that it was actualy supposed to do that.
View John Ormsby's profile
John Ormsby
1288 posts in 3792 days
#3 posted 09-15-2011 11:54 PM
You will need to use either Epoxy or Urea Resin glues to keep the lamination from springing back. One must also play around with the thicknesses and tightest curve desired that will work.
-- Oldworld, Fair Oaks, Ca
View shipwright's profile
shipwright
8006 posts in 2853 days
#4 posted 09-16-2011 01:03 AM
I’d go with urea formaldehyde as the best glue. Epoxies need a little room and if clamped too tightly as in a sharp lamination can fail as all the glue is driven out of the joint. If you want to use epoxy, add a thin glass cloth or the like to prevent this.
Generally though, spring-back can be reduced by using more, thinner laminations.
View DLCW's profile
DLCW
530 posts in 2709 days
#5 posted 09-16-2011 02:59 AM
Plastic resin glue (DAP Weldwood). Little or NO springback. I use it exclusively for bent lamination and veneer work. My local Ace Hardware carries it.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View fussy's profile
fussy
980 posts in 3106 days
#6 posted 09-17-2011 01:44 AM
Paul and DLCW are on it. The problem with most glues is they introduce too much moisture. As the glued up form dries, it shrinks and springs back. Urea formaldehyde won’t/ Wear a respirator and have pleanty of ventillation.
steve
