Do you trust a 2x4...
Forum topic by AwlThat posted 12-11-2018 04:20 PM 992 views 0 times favorited 39 replies Add to Favorites Watch
View AwlThat's profile
AwlThat
30 posts in 324 days
12-11-2018 04:20 PM
...to be parallel?
Assuming you found a straight board at the home center, how confident are you that the two faces are parallel to each and the two edges are parallel to each other?
I don’t have a jointer but I’d like to square up some 2×4’s, i.e. rip off the rounded corners, using just my table saw. I have seen plenty of videos on YouTube on how to do it, usually involving a jig of some type. But is all that really necessary?
I’m not looking to make fine furniture or anything, just a nice looking base for a Paulk-style table.
39 replies so far
View jonah's profile
jonah
1972 posts in 3536 days
#1 posted 12-11-2018 04:22 PM
I’ve never found what I’d describe as a “straight” 2×4 at the home center. I’ve found ones that are straight-ish, and that required digging through probably 30-40 boards to find one good one.
AwlThat
#2 posted 12-11-2018 04:27 PM
But even if the board was bent, how parallel do you think the faces are to each other?
Twisted is another story, but if it’s bent on one axis, how parallel do you think it is?
jonah
#3 posted 12-11-2018 04:34 PM
It’s probably pretty parallel. Certainly when it was cut at the mill it was parallel.
You might have better luck with something like 2×10s. A lot of 2×4s have the pith in them and so they end up cupping, twisting, and generally misbehaving. With a 2×10 you can rip the pith out and end up with two more stable boards in the end. You’ll pay a little more, but it may be worth it.
View tomsteve's profile
tomsteve
897 posts in 1457 days
#4 posted 12-11-2018 04:38 PM
- jonah
ive gotten some 2 by 10’s and 12’s that contained the pith but had a nice quatersawn outside of that area. seems i see tighter growth rings in the 10’s and 12’s,too.
View Monty151's profile
Monty151
34 posts in 79 days
#5 posted 12-11-2018 04:48 PM
Little known fact. This is the tree that Big Orange and Big Blue get their lumber from.
View Aj2's profile
Aj2
1950 posts in 2036 days
#6 posted 12-11-2018 05:33 PM
I found a perfect 2×4 once. I still remember that day it was the best day of my life.
-- Aj
View Bill White's profile
Bill White
5148 posts in 4198 days
#7 posted 12-11-2018 06:32 PM
Straight? The moment you bought it…..sure. The moment you got it home? NOT!
-- bill@magraphics.us
AwlThat
#8 posted 12-11-2018 06:35 PM
- Bill White
Like a ripe banana at the grocery store, right?
View Manitario's profile
Manitario
2703 posts in 3121 days
#9 posted 12-11-2018 07:00 PM
The only time I use a 2×4 without first running it through my jointer and planer is if I’m framing.
AwlThat
#10 posted 12-11-2018 07:07 PM
The only time I use a 2×4 without first running it through my jointer and planer is if I m framing.
- Manitario
That’s great, if one has a planer and a jointer.
If you didn’t have those tools, in your experience, how close do you think you’d get to a square board if you just ripped it on your table saw?
tomsteve
#11 posted 12-11-2018 07:16 PM
- Aj2
doin some remodeling on a 60+ year old house?
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#12 posted 12-11-2018 07:25 PM
When you find a perfect 2×4, go buy a sheet of plywood it might be true to size also, if so, you’ve hit a grand slam.
-- Bondo Gaposis
View Steve Peterson's profile
Steve Peterson
395 posts in 3320 days
#13 posted 12-11-2018 07:32 PM
The 2×4 that you buy from a home center may have been straight and parallel when it was cut. However, the log was green and will move as it dries.
-- Steve
View GrantA's profile
GrantA
946 posts in 1645 days
#14 posted 12-11-2018 08:20 PM
I’ll trust a 2×4 to do lots of things but being straight & accurately dimensioned aren’t in the realm of possibility
View Mosquito's profile
Mosquito
9566 posts in 2530 days
#15 posted 12-11-2018 08:24 PM
Often times things like nots or checks will cause a 2×4 to not have parallel sides, so I’d say buy a hand plane to make one side a known straight, and then rip it on your table saw.
If I want square curners, I’ve done what others have suggested, and buy 2×10 or 2×12’s and rip them down. Typically on the band saw, because I’ve seen some pretty nasty 2x’s cut on table saws immediately try to close up the cut on the blade. At the very least, don’t do it with out a riving knife or tall splitter
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
showing 1 through 15 of 39 replies
