signing work
« back to Woodturning forum
Forum topic by Karda posted 12-11-2018 06:33 AM 670 views 0 times favorited 16 replies Add to Favorites Watch
View Karda's profile
Karda
1382 posts in 792 days
12-11-2018 06:33 AM
Hi use a permapaque pen to sigh my bowls however when I try to seal it it runs. can I seal it when i finish the bowl or should I sign after the finish is applied and leave signature bare thanks
16 replies so far
View cracknpop's profile
cracknpop
341 posts in 2587 days
#1 posted 12-11-2018 12:33 PM
I’m interested in a good signing option as well. I’ve used a fine Sharpie and then lightly mist spray lacquer over it, however the lacquer tends to cause the Sharpie ink to bleed./blur.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
View Gene Howe's profile
Gene Howe
11147 posts in 3666 days
#2 posted 12-11-2018 12:54 PM
I use a self inking stamp. Dunno what the ink is but, it doesn’t run when sprayed with poly.
View LittleShaver's profile
LittleShaver
455 posts in 857 days
#3 posted 12-11-2018 01:14 PM
I use an old wood burning pen to put my mark and date on projects. Allows me to fit into the hidden space available.
-- Sawdust Maker
View Dustin's profile
Dustin
611 posts in 978 days
#4 posted 12-11-2018 01:26 PM
Also watching, as I ran into this myself recently and would prefer a good signing method vs engraving.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View HokieKen's profile
HokieKen
7562 posts in 1376 days
#5 posted 12-11-2018 02:15 PM
Water-based finish won’t cause Sharpie to run. I sign my bowls on the bottom with Sharpie then put shellac on top without issue.
-- Kenny, SW VA, Go Hokies!!!
View Planeman40's profile
Planeman40
1330 posts in 2999 days
#6 posted 12-11-2018 02:20 PM
Being an oldtimer, I use a dip pen (sold by art stores) and India ink (also sold by art stores). When dry, I use shellac over the writing. Works great and you can some interesting pens that do calligraphy which makes the signature really look great!
View Jack Lewis's profile
Jack Lewis
369 posts in 1316 days
#7 posted 12-11-2018 03:56 PM
- Karda
I use a clear coat enamel rattle can to seal the signature. Lacquer can dissolve most other finishes.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
Karda
#8 posted 12-11-2018 05:31 PM
I have also used shellac and that runs as well
View Phil32's profile
Phil32
357 posts in 141 days
#9 posted 12-11-2018 06:17 PM
Water-based finish won t cause Sharpie to run. I sign my bowls on the bottom with Sharpie then put shellac on top without issue.
- HokieKen
The term shellac is used for a variety of liquid finishes. Some have an alcohol base; some have an ethanol base. If the base is a solvent for the marker you are using it will bleed. I use a water-based polyacrylic over Sharpie.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
Karda
#10 posted 12-11-2018 06:55 PM
ok the shellac I use is shellac, alcohol base, I ‘ll try the polycrilic that should work, didn’t think of that just started using it
View ArtMann's profile
ArtMann
1217 posts in 1054 days
#11 posted 12-11-2018 09:12 PM
“Alcohol” and “Ethanol” are the same thing in this context. It is possible to dissolve shellac in Methanol and Isopropanol as well. As far as I can tell, the only practical difference is the evaporation time. These are more powerful solvents than water, which I think is the solvent in most acrylic finishes.
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1968 days
#12 posted 12-12-2018 02:33 AM
Mike, use a #2 lead pencil. Once sealed it won’t come off unless the finish is stripped off. Thank me later…......... Jerry (in Tucson)
View bilyo's profile
bilyo
474 posts in 1340 days
#13 posted 12-12-2018 02:47 AM
- Planeman40
I do it similar to Planeman40. Only I use fine point felt tip pens than contain india ink. They are available at hobby/craft stores. Then seal it with spray shellac or poly. I also usually “prime” the surface with one or the other to make a smoother writing surface. Also, this keeps the ink from wicking into the grain and spreading.
Karda
#14 posted 12-12-2018 04:56 AM
thanks everybody, except Jerry he said I can’t thank him yet. I gtry everything abd see what workks best
Karda
#15 posted 12-13-2018 01:48 AM
thanks Jerry the the tip about the pencil work great
