Very interesting Plunge Router modification. with plunge capabilities while drilling. How are you controlling the depth when you are using the foot petal?
first, I'm setting the bit height with the screw (height adjustor) and the caliper and set (lock) the depth stop.
I remove the screw, and install the Pedal and I "step on it" till the depth stop engages, when I drill, I "step" 2~3 times (not in one "shot") to let the dust out.
Soon I'll post all the procedure of doweling, it takes minutes and the accuracy is amazing, looks like Lego.
Way to go Jigman (Niki). That looks like a great table. I like that ability for the plunging with a foot pedal. The only thing I can think of is it might be a little high, causing someone to loose their balance. Maybe it needs an addition to lower the pedal to almost ground level? Still a great jig.
Bill
You are correct, the Pedal is a little bit high but, when I'm drilling, my two hands are holding the work so, it's like you put your both hands on a table and lift one leg, I don't have problem but maybe, you can make some L extension to the pedal.
Red Headed Marganser
Considering that my hand skills are…lets not talk about it…I developed this "Idiot proof" method.
What I like in this method is that the holes are drilled very clean, straight, flat bottom, fit exactly to the dowel size and the parts fits like Lego.
I think that this "Pedal" idea can be fitted also on "normal" router table without many modifications
I'm going to "shrink" (resize) the pics of doweling and post it by (your) tomorrow morning
I have enjoyed every one of your posts. I know when I see a new post from you, I'm going to see a well thought out elegant solution to a problem. You are the master of handmade jigs and fixtures.
very nice, i only have a garage that two cars go into every night, i just made a small router "box" that i set on a table, and im also using a plunge base until i can afford a fixed base. great idea! great work!
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
