Delta DC380 Planer Cleanup
Forum topic by Golfisher posted 12-07-2018 05:05 AM 226 views 0 times favorited 3 replies Add to Favorites Watch
View Golfisher's profile
Golfisher
9 posts in 532 days
12-07-2018 05:05 AM
Just picked up a DC380 and wondering what is the best way to clean up the surface rust on the planer bed?
-- Golfisher, NY
3 replies so far
View CaptainKlutz's profile
CaptainKlutz
602 posts in 1696 days
#1 posted 12-07-2018 06:01 AM
Same way you clean up surface rust on any cast iron table such as table saw or jointer?
scrap it, or
sand it, or
mill it.
There are a ton of rust removal threads on LJ HERE:
Also a pile of “Delta 15 planer threads too.
Best Luck.
View WoodenDreams's profile
WoodenDreams
290 posts in 113 days
#2 posted 12-07-2018 06:40 AM
I use WD40 spray the surface let soak for 10 minutes then sand with 500 or 1000 grit sand paper, wipe off as much as possible, wipe over with rubbing alcohol, then spray a protective coating of “silicon free Dry Lube” wipe off excess and back to planing
Golfisher
9 posts in 532 days
#3 posted 12-08-2018 07:59 PM
Thanks for the replies guys!
-- Golfisher, NY
