How Do I Cut Round Coasters?
Forum topic by Mean_Dean posted 09-12-2011 08:06 PM 5678 views 0 times favorited 26 replies Add to Favorites Watch
View Mean_Dean's profile
Mean_Dean
6418 posts in 3114 days
09-12-2011 08:06 PM
I want to make a set of round coasters (to set a beverage cup on), and can’t really think of a good way or jig to do the outside cut. I want them to be perfectly round, not cut on a bandsaw and sanded.
Does anyone know of a good jig that’s quick and easy to make and use? Any help will be greatly appreciated!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
26 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3615 days
#1 posted 09-12-2011 08:08 PM
template and router table
View willie's profile
willie
533 posts in 2421 days
#2 posted 09-12-2011 08:12 PM
You could turn a cylinder on the lathe and slice off coasters on the tablesaw.
-- Every day above ground is a good day!!!
Mean_Dean
#3 posted 09-12-2011 08:12 PM
PurpLev,
Thanks for responding. Router table is no problem, but how do I get the template perfectly round to cut an outside curve?
View TheDane's profile
TheDane
5401 posts in 3630 days
#4 posted 09-12-2011 08:14 PM
You could turn a block of wood to the diameter you want your coasters to be on the lathe, then slice to the required thickness on the bandsaw.
—Gerry
PurpLev
#5 posted 09-12-2011 08:16 PM
you could use a large hole saw, or use a bandsaw with a circle cutting jig (if you have a clean blade you shouldn’t have to sand the template, although you could smooth it out if you choose to). both will result in a center hole which the router template solution will not have so might be more fitting.
the lathe idea is also great if you have one.
Mean_Dean
#6 posted 09-12-2011 08:17 PM
Gerry, I don’t have a lathe. I’m thinking about a hole-saw but it will leave a rough edge, which will require sanding, thus making it not perfectly round….
View Blakep's profile
Blakep
232 posts in 2769 days
#7 posted 09-12-2011 08:22 PM
Find you something that is the size that you want and use turning tape to stick it to a block of wood and use your router with a flush cut bit and let the bearing follow the round object that you are using.
willie
#8 posted 09-12-2011 08:22 PM
You’ll need to find something to use as a template. Cut blanks close to finish size. Attach to template and trim with flush trim bit on a router table.
Mean_Dean
#9 posted 09-12-2011 08:32 PM
Ok, sounds like I need to find a perfectly round object to use as a template, rather than creating one myself.
But if I could make a template myself, I could make it the exact size I want for my coasters.
There has got to be a way to make a template!!
TheDane
#10 posted 09-12-2011 08:46 PM
Is a hockey puck (3” in diameter) big enough?
—Gerry
TheDane
#11 posted 09-12-2011 08:55 PM
If you have a flush trim bit with a replaceable bearing, you could install a bigger bearing and use a hockey puck to get a larger diameter. They are perfectly round, and at one inch thick, might make a decent template.
—Gerry
View richgreer's profile
richgreer
4541 posts in 3041 days
#12 posted 09-12-2011 09:11 PM
Another option for making a coaster is a hole saw.
A suggestion regarding coasters – - Drill a shallow flat hole in the bottom of the coaster and insert a magnet. Glue the magnet in place. (Epoxy or thick CA glue).
Why? – The coasters will stack very nicely.
I use a 3/4” forstner bit and an 18 mm by 3 mm rare earth magnet, but you could get by with a smaller magnet.
Blakep
#13 posted 09-12-2011 09:25 PM
I think the only way to make the template and having it perfectly round without sanding is going to be a lathe. You could draw a perfect circle and cut it out with a bandsaw and then get after in with a block with sandpaper and a caliber but good luck with that. The hockey puck or anything perfectly round to use as a template would be the way that I would do it. Just write template on the first one you make and then you can say you made the template haha
PurpLev
#14 posted 09-12-2011 09:30 PM
if you were around me you could stop by and we could turn a template for you. maybe there are turners around you that wouldn’t mind helping out?
View higtron's profile
higtron
235 posts in 2644 days
#15 posted 09-12-2011 10:14 PM
I cut my discs for my drum sander on my cross cut sled on my table saw, from the edge of the sled measure over to your radius point drill a small hole I used a 1/4” and a 14” dowel for the pivot point drilled a shallow hole centered in your blank just keep cutting facettes off the square blank until it’s almost perfectly round your last move is to spin the disc through the blade slowly, and you’ll have a real nice circle and supriseingly smooth it’s fast too. This is a technique I got from Jim Toplin’s Tablesaw Magic only he made a special fixture that rode in his miter slot in my case I already have one it;s my crosscut sled.
-- A friend will help you move, a good friend will help you move a body
