Joinery issue
« back to Joinery forum
Forum topic by Mark posted 12-06-2018 06:24 PM 283 views 0 times favorited 6 replies Add to Favorites Watch
View Mark's profile
Mark
971 posts in 2175 days
12-06-2018 06:24 PM
The Gents dresser I’m making has a solid shelf in the middle. In its construction it has full thickness panels (7/8”) running at right angles to the framework. All joints are young and groove. For whatever reason I glued everything together….frames and panels. Still not sure why I did that. Bottom line is those panels are going to move aren’t they? So I’m kinda buggered.
Whatcha think?
-- Mark
View Manitario's profile
Manitario
2681 posts in 3083 days
#1 posted 12-06-2018 06:32 PM
I’ve done the same several times. The result is that I have several pieces where the panel has cracked as it expanded. So yeah, you may need some repairs in the future.
View PPK's profile
PPK
1199 posts in 1010 days
#2 posted 12-06-2018 07:22 PM
Yep, looks like that won’t last/look nice for long. Looks pretty right now though!!!
You could get the same look by either gluing together some plywood in that orientation, or doing some veneering on a solid piece of plywood…
-- Pete
View Mark's profile
Mark
#3 posted 12-06-2018 09:49 PM
Sigh!! Manitario. I gotta agree with Charles Neil.
Thanks for the tips PPK.
-- Mark
117328 posts in 3777 days
#4 posted 12-06-2018 09:59 PM
Find this online it will help next time.
Understanding
Wood Movement
Proven methods for dealing with
expansion and contraction
B Y C H R I S T I A N B E C K S V O O R T
View bilyo's profile
bilyo
419 posts in 1303 days
#5 posted 12-07-2018 03:44 PM
As stated above, you are likely to have some problems in the future. I would consider cutting it apart along the glue lines and then trim the panels to allow for some movement. Then put it back together using loose tenons for the frame (glued) and loose splines (glued one side only) for the panels leaving them to float. You may need to add a thin strip along the back edge to compensate for the two saw kerfs needed to cut it apart. I think it is best to do this now before you apply a finish.
View Mark's profile
Mark
#6 posted 12-07-2018 11:52 PM
Thanks for the thoughts billowing. I’ve sorta resigned my self to that solution. Grasping at straws I guess.
That’s for the good read a1Jim. The stupid thing is I knew not to glue it for just those reasons…but I did anyway.
Sigh!!
-- Mark
