How can I get my wood harder?
Forum topic by 404 - Not Found posted 09-12-2011 05:27 PM 3799 views 0 times favorited 10 replies Add to Favorites Watch
404 - Not Found
2544 posts in 2968 days
09-12-2011 05:27 PM
Anyone know of a little blue pill that will work on a walnut table top? I’m considering applying wet rot wood hardener to a project I’m making – to keep it dent free for a long time to come. Any suggestions? It’s going to get 3 coats of a/c lacquer to finish.
10 replies so far
View higtron's profile
higtron
235 posts in 2676 days
#1 posted 09-12-2011 06:35 PM
Show it some racey pictures of exotic wood.
-- A friend will help you move, a good friend will help you move a body
View Dallas's profile
Dallas
3599 posts in 2486 days
#2 posted 09-12-2011 07:17 PM
Walnut and Oak, (of varying Species) have about the same hardness. I’ve used black walnut for cutting boards with no problem. If you have good dry walnut you shouldn’t have a problem with dents unless you are dropping an anvil on it.
Good Luck, YMMV
DF
View Jesse.R's profile
Jesse.R
55 posts in 2924 days
#3 posted 09-12-2011 07:28 PM
you could use a harder finish just on the top like a low viscosity epoxy or balins rock hard table top varnish.
-- jesse
View Bertha's profile
Bertha
13528 posts in 2692 days
#4 posted 09-12-2011 07:31 PM
What happens when you soak wood for a period in BLO? I honestly don’t know but I’ve soaked some very brittle wood in BLO and it seems to moisten and “harden” a bit.
View devann's profile
devann
2246 posts in 2691 days
#5 posted 09-12-2011 08:39 PM
Grandpa taught me long ago that BLO (boiled linseed oil) can be used to harden wood. He said that after the water had dried from the cells that replacing it with oil will make the wood harder. I’ve used BLO to harden walking sticks that I carved in the past with some success. I believe that the oil also helps to give the wood some elasticity, making minor dents pop back to the former shape the wood had before adding the oil.
404 - Not Found
#6 posted 09-12-2011 10:47 PM
Hmmm, just been in the workshop trying to simulate the damage an excited three year old can do with a die-cast firetruck. I’ll be taking a trip to the hardware store tomorrow to test the wet rot treatment and see how that holds up after interrogation by Mr Estwing.
View rance's profile
rance
4258 posts in 3159 days
#7 posted 09-12-2011 11:03 PM
Thin CA glue.
View Flyin636's profile
Flyin636
57 posts in 2493 days
#8 posted 09-14-2011 04:54 AM
Probably not the answer you’re looking for,am taking it that you want a “coating”.But wood does harden with heat.Have done it successfully with Oak,Bamboo…and I know theres at least one highend flooring co that uses a proprietary process on mostly Maple.636
View 489tad's profile
489tad
3366 posts in 3010 days
#9 posted 09-14-2011 02:35 PM
If you have the time you could petrify it. :) Ok, I’m sorry. I’ll go now.
-- Dan, Naperville IL, I.G.N.
View tyskkvinna's profile
tyskkvinna
1310 posts in 2985 days
#10 posted 09-14-2011 03:37 PM
I would likely do a relatively thin coat of bartop on top.. You can’t get much harder than that.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
